Question about Samsung RF26XAERS
Water collecting under crisper draws& freezing
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: water is collecting and freezing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 23, 2011
imufo2
  • 3773 Answers
SOURCE: Fridge is collecting water under the crisper
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 16, 2011
  • 54 Answers
SOURCE: WATER LEAK SAMSUNG RB215LASH
When water is leaking inside of your refrigerator, the problem could be as simple as condensation from humidity or a worn gasket, especially since you purchased your refrigerator used. The problem could also be a clogged drain or frozen evaporator.
To help you determine the problem, along with solutions that you can use, check out Refrigerator leaking water inside for some simple troubleshooting steps. I hope that helps!
Posted on Aug 02, 2012
Why is everything in the crisper drawers freezing?
Crisper draws are at bottom of fridge, cold air collects at the bottom and warmer air rises. Turn thermostat dial down, mine is set on 2 out of 6 and every thing stays fresh and doesn't freeze. In very hot weather I do sometimes turn it up to 3.
Dec 03, 2016 | Refrigerators
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Water collecting under bottom draws inside frig
That water is very likely dripping from the freezer because the drain for the defrost is blocked,so instead of the water draining its dripping through the vents down under the crispers. This tip i wrote will help ya to clear that drain to keep the water from dripping through the vents.
http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Magic Chef CTF1826AR Top Freezer...
Water collecting under crispers
Probably a plugged drain.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 28, 2009 | Electrolux Refrigerators
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Teacuptess my GE top freezer Refrigerator has water under Crisper
Could be but more than likely the drain is clogged. Open fridge door look at the top back to see if you can see water running down back of liner.
Jun 06, 2009 | Refrigerators
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Samsung RF26XAERS Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
