Question about Canon PowerShot SD1000 Digital Camera
Camera says "memory card full" and there is nothing on the card.
I got my camera today and charged the battery all the way and put everything in the camera. I did a test movie just to experiment with it and took a 15 second video, and then deleted it, and now it says the memory card is full. but it's not! I don't understand. Please help! Thanks
  • Anonymous Nov 09, 2007
    I can't get to the menu that says to delete pix on the memory card. I tried to follow the directions in the manual but it didn't work, duu!
    Problem Solver:
  • 19 Answers
Go into the camera's system menu and look for "format card" doing this will enable the camera to utilize the memory card. let me know if this helps, if not there are other things we can try.
Posted on Jul 05, 2007
  • rhonda.curran May 25, 2013
    What are other things we can try, i dont have the option for format card on my camera or if it do, i dont know how to find it..
Might not solve current problem but get at least a gig or 2 memory, card with camera is too small 32m to mess with. always reset card in case of problems
Posted on Aug 06, 2007
SOURCE:
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
Built in memory full and I have only taken one photo.
Have you inserted an SD card as the built in memory on the camera is only 12.7 Mb big so an SD card should be inserted. Hope this helps.
Jul 04, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
I got my camera 3 weeks ago. Now Im on vacation in Thailand and used the camera snorkeling. Yesterday the camera "froze" so the only way to get it going again was to remove the battery. Today...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 04, 2011 | Pentax Optio W90 Digital Camera
We had a splash of water come up on our D40 today and now it will not do anything. We have charged the battery to 100% and still nothing, have any recommendations?
Dismantle everything you can from the camera (battery, memory card, lens), try to pour out as much 'free' water as you can and let it dry for a couple of days.
DO NOT PLUG THE CAMERA TO THE MAINS, COMPUTER OR ANY ELECTRICAL CONNECTION until you can fire it up with the battery itself.
If your camera doesn't come to, you need to take it to the authorized dealership.
Jun 22, 2010 | Nikon D40X Digital SLR Camera Digital...
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
[email protected]
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 13, 2009 | Cameras
My Kodak af 3x optical aspheric lens camera won't turn on. it was fine yesterday but today it wont turn on. I've charged it and everything but it doesn't do anything. Help!
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Cameras
MEMORY CARD
I had the same problem today with a 2 GB card. I think it may be the size of the card. When I put in an old 32 MB card it worked fine.
Dec 26, 2007 | Vivitar ViviCam 3785 Digital Camera
Pentax K10D Both LCD screens are blank
Did you put a memory card in the camera?
My camera did this today, and I resolved it by putting a memory card in, but even when one has been out before it still turned on, so I'm not sure that is the resolution. Did you ever find out what was causing it?
Sep 29, 2007 | Pentax K10D Digital Camera with 18-55mm...
Camera says "Memory Card Full" but the card is empty...
Hi, First, lets try formatting the card. But be aware that it will erase everything on the card. 1 Turn on the camera 2 Press the Menu button 3 Toggle once to the left to get the Setup menu (the one with the hammer/wrench icon) 4 Toggle down to Format 5 Select OK and press the Set button. To perform a low-level format, press the up arrow and then the right arrow to add the check mark. After you do this, exit the menu by pressing the Menu button. Take some still photos first. Download them to the computer but don't delete them from the card yet. Disconnect the camera from the computer (or if you are using a card reader remove the card). Delete the images from the card by using the menu in the playback/review mode. Let me know if this solves anything.
Jul 01, 2007 | Canon PowerShot SD1000 Digital Camera
Camera just wont turn on...help please
I opened up mine today and found out that all you needed to do was put the plastic gear back into place and it's A ok. Open up the camera and when you're facing the front, check the little plastic compartment on the top right to see if the gears are in place. I fixed it and everything is A ok now. :)
Nov 19, 2006 | Casio Exilim EX-S600 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
155 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
