Question about Refrigerators
My Maytag MBB1956GEQ
The freezer repeatedly gets hard frost behind the back panel of the compartment. Eventually it stops making ice, and ice cubes in the tray dry up. Twice now I have shut off the freezer and defrosted it for several hours using a heater. That does the trick, and it goes back to normal, including making ice. But only for about a week, Then I notice a repeat of the problem starting---that is, clogging of the back panel and vents with ice. What's wrong? Have any solutions? Seems like the defroster gets clogged, since the ice cubes are wetter than they should be too.
  • Refrigerators Master
  • 4,654 Answers
Your refrigerator appears to have a defrost problem. There are three parts tothe defrost system that may be causing the problem. The defrost timer located inside the controls panel just above the top shelf of the fresh food compartment. The defrost timer is seen as item 12 in this photo=> MBB1956GEQ_Controls Lets try to force defrost by turning the defrost time slowly clockwise until the compressor and fans stop. Leave the defrost timer like this up to 35 minutes and if the compressor and fans do not come back on automatically then the problem is the=> 67001036 Defrost Timer
If the defrost timer functions properly and still the refrigerator does not go into defrost we will need to move to the defrost heater=> 67002135 Defrost Heater Assembly
and the defrost thermostat=> 12001937 Defrost Thermostat
The defrost timer and defrost heater are found inside the back wall of the freezer and the defrost heater can be tested by the instructions found on the same page as the 67002135 Defrost Heater Assembly
If you have any questions I will be here should you need more answers, Thanks Sea Breeze
Posted on Jan 09, 2013
  • Chris Jan 09, 2013
    Oh boy. I sense you are probably correct. Now to go exploring. Ug! Thanks.
  • John Tripp
    John Tripp Jan 09, 2013
    Thank you for your rate! I wanted to say the defrost heater and defrost thermostat are found behind the rear panel inside freezer. Thanks again, JT
peyton32034
  • 410 Answers
SOURCE: Kenmore Coldsport freezer drain repeated freezes
probably the easiest fix for this is install a drain probe to transfer heat from the defrost heater into the drain hole to prevent ice build up. take a peice of 10 or 12 guage solid copper wire and wrap one end around the defrost heater pretty tight and put the other end down in the drain line 2-4 inches.
Posted on Dec 15, 2007
  • 958 Answers
SOURCE: Evaporator coils frosting up
the frosting of the back compartment of the freezer indicates that the ice builds up at the evaporator ( the coil that cools). the system is supposed to melt the ice after a particular time interval for a period of time in order to start another cycle. im not sure if that model uses the electronic timer which you can not manually adjust to see if it is heating up on the heating mode. you would have to check three things. one is the defrost heater itself if it has continuity. another is the thing that we called thermodisc . its a part of the heating circuit where it cuts the heating current after it senses that the temperature of the evaporator is way up the thaw temperature. it is normally connected in series with the defrost heater and it is attached to the latter part of the evaporator tube. lastly which as i have told you is the timer. if its a mechanical timer, then probably it is not going to the heating mode. another is the electronic timer which is very hard to trouble shoot. you have to really observe the refrigerator how long it is running and if the compressor is stopping and the heater working by looking at the back if water is draining after a few minutes the compressor stop. as i may add, as you have said it is winter there, a thermostat setting could be an issue. the heater could probably not cope up with the coldness of the ambient temperature in which i may suggest to put the thermostat setting to the lowest setting on the knob. i hoped i was able to help....drcool
Posted on Feb 05, 2008
22yooper
  • 828 Answers
SOURCE: clogged defrost drain tube
You can access the drain tube from the back of the refrigerator. There is normally a trap located after the drain line exits the freezer compartment. Clean out the trap and it may solve your problem.
Posted on Apr 29, 2008
SOURCE: Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Posted on May 03, 2008
freetek
  • 5568 Answers
SOURCE: Kitchen Aid bottom freezer has frost/ice buildup
Do you know for certain that the automatic defrost cycle is running at all?
Depending on the model, it should be entering the defrost mode every 12 or 24 hours. If the defrost timer is not easy to see (because of the drawer construction), you should be able to catch it by checking the walls of the freezer at random to see if they are still 'ice' cold or more temperate.
You may definitely have a leak, no argument there, but the defrost cycle may have been masking it while it was still happening by sending the ice/water down to the pan.
Posted on Jan 18, 2009
Maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Mar 26, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
Freezer gets cold refrigerator doesn't
check the damper door located between the freezer and refrigerator compartments(this lets in the cold air from the freezer) and make sure it opens and closes with your temp adjustment in the refrigerator compartment,sometimes they ice-up and are frozen in one position then take a hair dryer and defrost the door
Mar 13, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
Our side by side side by model was purchased in 2002 and has been problem free. Starting about two weeks ago following a party, there has been a continual frost build-up in the freezer. I have removed...
You have a bad freezer door gasket!! it's letting moisture seep into the freezer and once the moisture hits the extream cold it turns to ice crystals.The freezer is designed to get as cold as 0 degrees and the ice cubes stay in cube form as long as the temp is below 32 degrees so the ice cubes didn't make a difference.You can try and CLEAN the contact surfaces of the gasket and freezer real good this usually works,if the gasket is damaged you will need to replace it.
Sep 20, 2009 | Maytag MSD2454G Side by Side Refrigerator
GE GSS25KGSA.... the freezer is no longer freezing regardless of temperature setting. It gets cold but no freezing. There used to be more noise during cycles, but that has stopped also.
The fan that circulates air in the freezer compartment is frozen & not circulating air - resulting in a freezer compartment that is cool but not cold. The reason is that the “heater & bracket” that warms & defrosts the evaporator coil & the fan above it has died & w/no defrosting, the coil & the fan load up with frost & ice & stop working.
Temporary Solution:
1) Unplug the frig.
2) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
3) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes. (if you leave them in the freezer, they will melt & refreeze & make a disaster).
4) There is a metal panel below the lights & it should have frost & ice built on it.
5) Get two (not one) hair driers, set them on high heat & melt all the frost & ice & keep on melting & defrosting for about 10 minutes.
4) Plug the frig back in.
5) The freezer fan should be turning.
6) Put the shelf & food back in & close the door.
7) Expect this problem to reoccur in one to four months...
Solution:
1) Get a “heater & bracket” GE part number WR51X10055, about $30 w/shipping on eBay. This is for a GSS25KGSA GE side by side (the last two letters WW, BB, & CC are colors). If you have a different GE side by side, the correct part number can easily be found at www.searspartsdirect.com. Nice drawings.
2) Unplug the frig.
3) Take all the food & shelves out of the freezer. Put it ALL in one cardboard box; this will keep it from defrosting while you get the freezer working.
4) Take out the ice maker storage bin (the thing that's full of ice cubes) & dump the ice cubes.
5) Take out the light cover. One Philips screw on top & two press-to-release plastic things on the bottom.
6) Unscrew the light bulbs.
7) Take out the metal panel below the lights. Four ¼” screws. It is held in by two tabs at the top, so swing the bottom out & pull it down. Be careful not to bend it.
8) Get two (not one) hair driers, set them on high hot & melt all the frost & ice on the evaporator coil. Do NOT touch it.
9) Remove the “Heater & Bracket” by unscrewing the two Phillips screws and then unplugging the red & blue wires.
10) Install the new “Heater & Bracket” by plugging in the red & blue wires & replacing the two screws. Be careful not to get it backwards when plugging the wires; only goes one way.
11) Put the back panel back in & secure it with the 4 ¼” screws.
12) Reinstall the lights & cover.
13) Plug the frig back in.
14) Put the shelves & food back in & close the door.
15) Expect this problem to reoccur every 3-4 years; great designs fail after the warranty is up, and keep the repairmen & parts people employed …
p.s. about once a year, you should vacuum all the accumulated dust off the condenser coils. They are hidden behind a metal cover at the bottom back of the refrig. If you don't, expect the dust eventually block all airflow & the compressor will burn up & you will be buying a new frig.
Generic GE Side by Side Refrigerators GSS25KGSA, GSS25KGSAWW, GSS25KGSABB, GSS25KGSACC.
Jul 08, 2009 | GE Refrigerators
Freezer side will not keep ice cream, popsicles or orange juice frozen. it will make ice in ice cube trays-the ice maker makes very few ice cubes.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check
, defrost heater, defrost thermostat.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Frigidaire FRS6R5EMB Side by Side...
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Freeaer and refrigerator warm
Check and clean the condenser coil in the back behind a removable panel. after cleaning make sure you replace the panel. Check the back inside wall of the freezer compartment for frost build-up. If there is frost on the back wall you have a defrost system problem.
May 23, 2008 | Maytag Refrigerators
Fridge stopped getting cold
Check for frost on the back wall of the freezer section. If there is frost there your problem is defrost related to a timer or defrost heaters. I say this because you indicated it still makes ice cubes which indicates it is still working to some degree. Check the condenser for cleanliness and clean if necessary. Under the refrigerator front behind toe plate and /or in back behind removable panel.
May 19, 2008 | GE Refrigerators
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
