Question about Karcher 2500 PSI Pressure Washer
Honda GC160 was leaking gas. Relaced gaskets but need help in reinstalling the choke.
3 Suggested Answers
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
  • 623 Answers
SOURCE: Pressure washer with Honda Engine GC160 only run
The carb is clogged. It needs to be cleaned, or replace. Keep in mind some of the carb passageways are as small as a human hair so they are difficult to clean which is why I mention replacing. You can try using carb cleaner etc in the gas, but I don't think it will work if you need the choke that much.
Posted on Apr 30, 2010
Troy-Bilt 2500 psi / Honda GC160. 5.0 hp. No manual. What weight oil? Straight gas or also mixed with oil?
Hello, I have found this for you. The first link is to the engine manual page and, The second is to an owners manual that may be what you need.
hope this helps. :)
http://engines.honda.com/parts-and-support/owners-manuals/gc160
www.e-barnett.com/ProductDocument/10148/2490717_Owners.pdf
Aug 08, 2016 | Honda Garden
I have gas in my oil on my honda 5.0 gc160
Check the engine compression with a compression tester. Most likely you have a blown head gasket.
Sep 19, 2014 | replacehondaengines.com Honda 5.0 Hp...
I am getting gas In the crankcase. engine back fires run only with choke out
float is stuck, bad needle and seat, debris between needle and seat and check air cleaner made sure it not oil or fuel soaked even if dry replace
Sep 18, 2014 | Honda Horizontal Engine 5 HP OHC 3/4 x...
I have a Honda GC160 5 horsepower power washer with 2400 psi. When its cold it is easy to start but after it has been running for a while the only way to start it is to have the water shooting out of the...
you are not choking it for warm restart are you?? maybe you have a carb clog issue?? try running seafoam in your gas for a tank or two...just 2 ounces at a time is good. dont overdo it!!
Jun 29, 2017 | Garden
Pressure washer with Honda Engine GC160 only run with choke fully closed.
Apr 29, 2010 | Karcher 2500 PSI Pressure Washer
Motorbike stalls when openeing throttle or turning choke off.
You've most likely got plugged up carburetor jets. The openings in the jets are so small that it can be very difficult to tell when they're plugged up - and this makes them clogg very easily, too.
The only other possible cause of the trouble you describe would be an air leak between the carburetor and the engine, a leak at the head gasket or cylinder base gasket, or a leaking crankshaft seal.
Nov 03, 2009 | Honda NSR 125 Motorcycles
Washer want stay running. I can pull choke and it
mr fixit, I have pressure but it just want stay running
Jul 11, 2009 | Garden
I need an IPL for Honda GC160 5hp engine
This may help. Get the name and number off from the carb such as walbro or zama to name a few and go to that indivdual web site and print out a parts list. I have done it many times and it works for me. I hope this will help. Donnyb60
Mar 19, 2009 | Husqvarna Garden
Karcher 2500 PSI Pressure Washer Logo
81 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
