Question about Microwave Ovens
Ge profile microwave starts when the door closes does not heat but the light,turntable& fan are on pvn1870smc02
  • Microwave Ovens Master
  • 9,085 Answers
I'm assuming you mean "PVM1870SMC02", which is the Canadian version of the US model PVM1870SM2SS.
With the symptoms you describe, you likely have a shorted main relay (lamp relay) on the unit's controller.
This can be economically repaired. Details are here.
Posted on Jan 09, 2013
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave runs with door open
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
SOURCE: Turntable repair? GE Profile model JVM1660BB
IF EVERYTHING IN THE OVEN IS WORKING BUT THE TURNTABLE YOU HAVE TO TAKE THE BOTTOM COVER OFF THE OVEN THE MOTOR HAS TWO WIRES ON IT, BE CAREFULL
WHEN YOU TEST IT AS THERE IS 110V ON THE WIRES.IF THE 110V IS THERE BUT THE MOTOR ISN,T RUNNING TAKE THE
TWO WIRES OFF,AND TAKE THE MOTOR OUT AND BUY A NEW ONE. YOU CAN DO THIS BUT DO BE CAREFULL.. YOU
MAY HAVE TO PULL ON IT A LITTLE TO PULL IT APART FROM THE PEACE INSIDE THAT TURNS THE GLASS TRY NOT TO BREAK IT!
Posted on Jan 22, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: GE XL 1800 microwave light and fan operate but no heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
If it's within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), G.E. will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the mag warranty, G.E. should send you the magnetron to do it yourself. Call them at 888-239-6832 with your model, serial, and manufacturing date.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer.
You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620 or here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Mar 02, 2009
  • 178 Answers
SOURCE: GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
Posted on Sep 11, 2009
heatman101
  • 43501 Answers
SOURCE: Our GE Profile Spacemaker microwave started making
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sgfhg
Posted on Sep 30, 2010
With the door closed, the oven makes a buzzing sound. If I try to microwave something, the interior light lights, the turntable turns, the normal fan sounds while the buzzing sound continues. No heat is...
You can possibly have a bad diode and or magnetron. When working on microwaves you have to be very cautious of what you are touching there is a capacitor inside that stores a voltage and can cause physical harm if not discharged.
Mar 21, 2015 | GE PEB1590SMSS Stainless Steel Profile 1.5...
Turntable turns when door opened
This is usually caused by a defective door switch, or it may be out of aligment. Since there are a few of them a digital meter is required to troubleshoot the problem area. If you have the equipment I well describe how to test them.
Jul 04, 2012 | GE Profile PT970 30" Built-In Double...
My ge Profile microwave convection oven (JVM1790) will not turn off. I don't think it is actually heating and the turntable isn't turning. However the light is on and it sounds as though it is heating...
sounds like the broken latch is your problem.yes you can buy a latch assembly and fit .broken latch does not activate micro switch so it is like having the door open.hope this helped you let me know
Jun 22, 2010 | GE Profile Spacemaker Over-the-Range...
Oven start turntable when opened
throw this machine away very dangerous!!!!!!!!!!!!!!!!! .. omitting radiation . that door is suppose to be sealed to avoid this problem
Sep 26, 2009 | GE JE1390 Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
