Question about Air Tools & Compressors
I have a paslode f350s it either misfires or only drives nails half way?
It misfires about every other nail and when it does fire it only drives the nails about half way
  • 104 Answers
SOURCE: paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Posted on Oct 22, 2008
rowdy45176
  • 2176 Answers
SOURCE: nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Posted on Sep 20, 2009
  • 12 Answers
SOURCE: My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Posted on Oct 04, 2009
rsmith972278
  • 160 Answers
SOURCE: how to load nails in the paslode f350s framer
Hi, I found you a free owners manual for your model. Click on the link below and save or print.
http://www.paslode.com/uploadedFiles/pneumatic_ops_manual.pd f
Hope this Helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Posted on Dec 29, 2009
atthings
  • 59 Answers
SOURCE: paslode nail gun isnt firing every time, remove
Cant help really but I strongly advise you not to fire the machine under any circumstances without nails and a piece of wood to try it on. tremendous damage to the mechanism can result.
Posted on Jun 15, 2010
My paslode impulse 1m50f18 fires normally but no nail apears with paslode nails?
not sure what you mean" no nail appears with paslode nails" if it fires make sure the nails are correct for your gun
Sep 08, 2015 | Air Tools & Compressors
Why is my gun bending nails?
Adjust the Work Contacting Element. See page 4 in the manual...
http://www.paslode.com/owners-manuals.html
Adjust the depth of drive.
Make sure correct fasteners are being used.
Use fasteners that meet Paslode specifications only.
Increase air flow to tool -- use larger air lines
(3/8 ID minimum).
Increase Air Pressure. DO NOT EXCEED 120 PSI.
Jul 23, 2014 | Paslode F350S PowerMaster Plus 30-Degree...
How to unjam paslode f350s nailgun
use the driver of the tool or a nail punch and hammer and try to knock out the nails
Sep 13, 2012 | Air Tools & Compressors
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
Why does my paslode f350S shoot one nail, but not shoot the next nail/
Had that problem on one of mine. If it is a multi degree nailer double check your degree setting. It will always shoot the first but will jam on the second.
Feb 15, 2012 | Air Tools & Compressors
Paslode f350s.just replaced all o rings,now when you pull the trigger air leaks out through the trigger,but only when depressed..will not fire nail.please help ..thanks bob
Simple. You have a leak you didn't have before. Either find it, or take it to someone who knows what they're doing. O-rings have a thickness, as well as a diameter. If you used generic rings, that's probably the problem. Use the repair kit by Paslode.
Paslode.com can tell you where your nearest dealer/repairer is.
HH
Dec 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
How to load nails in the paslode f350s framer purchased a used nailer now trying to figure out how to load the nails
Dec 29, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im250 f-16 only able to drive 2 nails .
Bad Fuel cell!!! New cyliders now have expire date on bottom of cannister. If old will not fire properly. Put new fuel cell in should be fine.
Feb 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Air Tools & Compressors Logo
172 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
