Question about Home
Why does my toilet occationaly overflow with no solid waste and just toilet paper
Several times in the last year my toilet has overflowed when flushed with no solid waste and just a little paper. There appears to be no clog in the line as normal operation resumes after the overflow. Is it possible that the cheap fixture from home depot manufactured "off shore " is at fault?
  • 979 Answers
Not really. I believe there is a clog in the trap. This happened to us last year. I took the toilet up and found a cloth in the trap ad a pencil. This fixed the problem. Now some traps are poorly designed and meet only minimum specs. Before taking it up, take a hose and force water down it wide open , this could blast out the obstruction.
Posted on Feb 04, 2013
3 Suggested Answers
  • 39 Answers
SOURCE: Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Posted on Aug 05, 2009
Digglesby
  • 71 Answers
SOURCE: Kohler one-piece has no flushing power
Don't flush more water! Trash the toilet and replace it with a toilet that uses less water and flushes efficiently; practically every manufacturer makes a dual flush or eco model. Spend your money on a good toilet rather than paying for and wasting water every day.
Posted on Nov 04, 2009
Repair basement ceiling from toilet overflow
If the toilet that overflowed had liquid and or solid human waste in it at the time of the overflow, then it is considered "black water" and a biohazard. You could let it dry out, but you may experience foul odors. It is best to open up the ceiling, clean the area, and repair if this is the case.
Apr 14, 2015 | Washing Machines
How do I remove a geberit waste and overflow fitting
Tub overflows have a connection behind the drain flipper. You will also need to get under the tub or into the wall behind the flipper to cisconnect the nuts connecting the drain pipes.
Oct 11, 2014 | Home
Toilet overflow
Unclog it and try it. It should be fine after it's unclogged.
Mar 10, 2014 | Computers & Internet
Toilet Tank overflow wasting water need manual.
Adjust the float so water level stops at 1/2" below top of overflow pipe.
Jan 07, 2014 | American Standard Home
The water will not refill! The inner plastic part doesn't work and it's only one year old! I must pour a bucket of water into the bowl to flush waste.
Does this tank have the plastic bucket around the flapper inside the tank. If so this is a water saver toilet. A few tricks to increase the water. I have had to remove the bucket by cutting it maybe half into to increase the gpm.
This will increase it to more than 1.6 gpm's. It can be cut down just be careful in doing it if this is the problem.
Next make surethe fill valve has line running and attached to overflow tube. This will fill the bowl with the needed water for it and the tank.
Next make sure the water is set to the mark either on the tank or the overflow tube. If no mark to within 5/8" to top of overflow tube .
Jun 27, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
I've just fitted a Nabis breeze and am having flushing problems.
Well many toilets flush very high before flushing, they appear to almost overflow, but if that doesn't seem like your problem, I would recommend adjusting the float on the Fluid-master fill valve so that there is less water in the tank when it flushes.
Apr 16, 2010 | Hansgrohe E & S Accessories 40526000...
THE WATER KEEPS FILLING PAST THE OVERFLOW.
Replace fill valve. Fluidmaster works quite well and is very adjustable.
Jan 21, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
When the toilet has been flushed (push button)it makes a hissing noise and then overfills so the water is going away in the overflow pipe. it was fitted 3 years ago. thankyou.
on your ballcock assembly there is an adjustment device (usually a screw) you just need to adjust the water level so it does not go over the overflow and have the "running" sound. there is a reccomended level usually stamped on the tank or the overflow tube.
hope this helps
Jul 07, 2009 | Home
Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Mar 30, 2009 | Facebook Social Network
Home Logo
66 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
