Question about Orion HCCA-D5000 Car Audio Amplifier
Dont know what i need to install
What do i need to install the amp plus 2 orion 12" hcca?
  • 67 Answers
Almost any electronic stores will have an amplifier installation kit
Posted on Jan 20, 2009
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
Features
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
Oct 26, 2009 | Orion HCCA 12D Car Speaker
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion HCCA-D5000 Car Audio Amplifier Logo
122 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
