Question about Panasonic TCL42U22 42 in. TV
My panasonic tcl42u22 keeps shutting off.
There is no picture, and I cannot see the menu select other inputs. Meanwhile it shuts off after about maybe 30 seconds or so.
  • Mike Johnson Jan 08, 2013
    There is no blinking. It just turns off. It does have an automatic shut-off feature,when there's no input, but that is easily dealt with. This doesn't look like that.
I HAVE A PANASONIC PLASMA TV,SERIAL NO IS TH-37PG9U,THAT STUCK ON HOTEL MODE,IT HAVE PC,DVD,AND NORMAL CABLE INPUTS,BUT NOTHING WORKS,HOW CAN I RESET IT TO WORK,THANKS IN ADVANCE
Be careful with this !
One wrong mis-setting and you could cause problems with your set.
On the TV itself, find the manual buttons down the side and select
-/V button press down and keep it pressed down meanwhile, on your remote...
Press the AV or TV/AV button three times in quick succession.
(depends which remote you have).
First press -/V then while still pressed down, press remote AV button 3 times
The menu will appear and you can change the settings.....just don't play around with it, it will go wrong very quick. Just stick to the objective and you'll be fine.
Oct 17, 2016 | Panasonic Televison & Video
Why tcl42u22 has no power
Panasonic tc-l42u22 4amp fuse blows replace 2 diodes nte#116 or nte 552 600v 1 amp silicon rectifier fast recovery
May 10, 2014 | Panasonic TCL42U22 42 in. TV
WHY DOES IT KEEP TURNING OFF
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Apr 24, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Panasonic 42in tv won't recognize video input
I assume you have checked the camcorder is compatible and is set on the same convertion ie pal/vega as the tv
Nov 10, 2013 | Panasonic TCL42U22 42 in. TV
Does anyone know what the specs are for a replacement fuse for the power supply board in a panasonic Viera TCL42U22?
Specifications to fuse differ with set to sets. Usually a 250V6Amps fuse used in most LCD TVs. If you wish to get more details, you have to download the repair manual to this set by internet. If you wish some details about this, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 07, 2013 | Panasonic TCL42U22 TCL42U22 42"" LCD TV
Vertical lines
There are mainly two reasons for this fault. Circuit board, and panel. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Panasonic TCL42U22 42 in. TV
Cant select menu to program channels
Unplug,replug the tv back about an hour later,u have a cable box,a satalite or a telicom compannies boxes.Do the same things.Let those boxes boot up and upgrades it softwares.Now u should able to go into the tv menu,go to PICTURE,go down to reset ur Tuner board back to factory setting.Still have the same problems after the tv and boxes reset,than ur tv the broscasting signal Tuner board is dead require replacing.
Jun 17, 2010 | Panasonic TCL42U22 42 in. TV
Panasonic TX-28PM1 TV shuts down after 2 seconds and then Standby LED flashes
Have you tried pressing the input selection button right after powering on the t.v.? Some t.v.'s go into standby mode when they are on a input selection that has nothing connected to them. Hope this helps some! Best of luck to ya!
Feb 15, 2010 | Panasonic Televison & Video
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic TCL42U22 42 in. TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
