Question about Canon PIXMA MP495 InkJet Printer
Canon mp495 ip address - Canon PIXMA MP495 InkJet Printer
2 Suggested Answers
  • 108 Answers
SOURCE: How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Posted on Nov 25, 2009
Testimonial: "Thanks, Can you please advice how do i print network setup page from this printer [Cannon ir3570]"
How do I find ip address for canon pixma mp 495 printer?
Two links for you
Pixma MP495 Printer not detected - Canon Community
community.usa.canon.com/t5/Printer-Multifunction.../Pixma-MP495-Printer.../25583
  1. Cached
  2. Similar
May 26, 2013 - So I have a Canon Pixma 495 printer that worked great wirelessly ... Hi I have the Canon Pixma MP495 and I can't seem to find the IP address.
PIXMA MP495 Wireless Connection Setup Guide - Canon Europe
www.canon-europe.com/.../pixma_printer.../mp495_printer_wireless_connection_set...
  1. Cached
  2. Similar
This method is by far the easiest way of connecting your PIXMA MP495, so if your ... Press and hold the [Maintenance] button (A) on the printer for approximately 5 ... regarding pressing the WPS button, please refer to the access point manual.
ip address for canon pixma mp 495 printer Google Search
Oct 04, 2016 | Canon PIXMA MP495 InkJet Printer
Printer canon pixma mp495 multifunctional
Since you've already performed a Factory Reset, which ought to take care of anything along the lines of corrupted system files, you might want to double-check that you have the correct drivers. Canon Support Drivers PIXMA MP495
Once you have the correct drivers, try doing a factory reset on your printer while it is not connected to your computer. Once complete, try using the USB cable that came with your printer to connect it to your laptop and install the drivers.
There is the possibility that your printer, even after a factory reset, is trying to automatically use WiFi for its connection to your laptop. Assuming you're using DHCP and not static IP addresses, try giving your printer a static IP address, as it may be fighting with some other LAN device for a particular IP address.
If it turns out you do have the correct drivers and you are using WiFi for the laptop to printer connection, I would suspect something is wrong with the WiFi connection on your printer's side or in your router's configuration. Make sure you have the printer's MAC address in the appropriate table in your router's filtering configuration, if you're running MAC address filtering.
Apr 06, 2014 | Computers & Internet
My canon mp495 printer wont function
it needs a reset. u need to to service mode to do it.
Feb 13, 2014 | Canon PIXMA MP495 InkJet Printer
Ip address check 2 05 4051
It's a funny thing but all I did was press the physical SCAN button on the MP495 - instead of trying to do it from a program in the computer. It scanned the document immediately and launched MP Navigator.
I had tried most of the solutions here first, with no success.
Sep 24, 2013 | Canon PIXMA MP495 InkJet Printer
Wifi set up pin #
Just checking, could that be the passcode (PIN) to access your Router WiFi set up? That could be found on the sticker on the bottom/side of your WiFi Router. I didn't see where the setup procedures from Canon address this.
Apr 21, 2013 | Canon PIXMA MP495 InkJet Printer
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
What ink will my canon mp495 take?
Quikshiptoner is a good site for ink and toner that I generally use. It has black and color ink for the MP495. I'd just go there and search for the printer you need and it should come up with the correct ink / toner that you need.
May 11, 2012 | Canon PIXMA MP495 InkJet Printer
What does Error code P03 mean on Canon Pixma MP495
Download the manuel from this link below:http://www.manualowl.com/p/Canon/PIXMA-MP495/Manual/68096
It might have some trouble info for you. ;-)
Jan 29, 2012 | Canon PIXMA MP495 InkJet Printer
Tried pushing the comcast router WPS button to set it with the printer, but its not working. help
Hi there :first your router must be " A commercial access point or router that supports IEEE802.11b/g/n is required. "You have to do the installation two times , folow this link :http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP495.aspx?faqtcmuri=tcm:14-774514&page=1&type=faq
I hope this information will help you.
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA MP495 InkJet Printer Logo
old marine
old marine
