Question about Tomtom ONE GPS Receiver
When I install my 2g sd card in my TT it just comes up with a screen that shows the TT unit with the sd card being removed and then it shows the sd card beside the unit with a red X over the card. I dont know it its saying not to remove the card or if its saying it has a problem with the card. I have heard that the TT One has to copy all info to the card but I have let it flash the image of the red X over the card for an hour and a half now can anyone help
    Problem Solver:
  • 6 Answers
Dude check it the tomtom needs an application, map, and at least one voice to work so before u start u need to formatt ur sd card to fatt 32 once u do that go to tomtom home and just update ur device an application and a ton of voices will come up grab the application and ONE voice now for the bad news when it comes to the map its a pain because they are kinda strict to be honest call tomtom support for help with the map they will walk u thru takin the map off the original sd card puttin it on the desktop then movin it to ur new sd card however sometimes there is issues wit the certifacation file this again is wher e u need tech support... use to wrk for tomtom....
Posted on Jan 21, 2009
Tomtom one (4N00.012) will not load up.
Your particular unit runs it's software from SD-Card. you need to check if the card is not damaged: while unpowered push the SD card to come out insert it in a card reader on your computer and see if it reads it ok, if it ask's you to format it it means it's damaged and should be replaced ( the sd card of your tomtom should be replaced with another SD card which you should buy from tomtom for your particular device not a generic one). if it reads just fine reinsert it and start the device again..And about the reset the correct procedure is: Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.904537f.gif
You should also install Tomtom Home on your computer, connect the device and update it if al the above failed (with a verified and working SD card inserted) - link for Tomtom Home: Windows, Mac
May 30, 2010 | Tomtom ONE 125 GPS Receiver
New tt card
I have several of these 'TT Cards' for my kids.
Firstly put the micro sd card in the sd card adapter and format it in your PC. When you go to format please slect restore default settings and then click format. (That is ofcourse if you have a micro sd card? If not a 2gb one will hold about 20 games)
Then open the location that you sd card is E: etc and create a new folder called Games. This is where all the .nds files you would have downloaded will be put.
You then need to drag and drop the latest firmware for the TT card onto the sd card in the PC. You can get i here:
http://www.neoflash.com/go/index.php?option=com_content&task=view&id=219&Itemid=27
Just download and unzip. If you need it winrar is a free download.
Ok, after you have done all of that you need to take the sd card out of the PC, put it into the tt card, put the tt card into the ds, turn on the DS and let it start up.
If all is done properly you should see a nice TT card menu on the screen!!!
Now turn off DS, remove tt card, take sd card out of tt card, place micro sd card into adapter and then into pc, open sd card location, open games folder and just drag and drop downloaded nds game files there.
Please remember only .nds files can be played on a flash cart of which a tt card is one.
Also look for a ds rom trimmer tool on google. Will make the game a lot smaller so you can get more on the card.
Hope this helps.
Anyproblems please message me back.
Best Wishes,
Karlos
May 15, 2009 | Nintendo DS Console
TomTom One series 30 won't reset
It sounds like you have lost the operating system or the flash memory card has gone bad. Make sure your unit is fully charged and try again. Then connect your device to your computer. If it comes up in my computer right click the drive and check properties to see how much space is availiable on the drive. If it says 0 the flash has gone bad, I have a 20 series tt that this happened to. My solution was to insert a sd card (at least 2 gb.) into the sd card slot found under the sticker no sd card requaired on the bottom of the tt. TT home then installed the operating system but the downside is if you have not made a backup od your tt you will have to buy new maps (not cheap).
Hope this helps
Apr 23, 2009 | Tomtom One XL GPS Receiver
SD card for TT one XL
Card needs to formatted using fat32 in windows formatting options, then copy and paste your back-up files one by one to your new card.
Hope this helps
Oct 16, 2008 | Tomtom One XL GPS Receiver
When turns on shows a computer screen and red cross
Go to TomTom Home reconnect and then go to device on the tool bar. Select disconnect device and this should free up your device and take the red X off.
Goodluck,
Please don't forget to rate my solution
Apr 26, 2008 | Tomtom ONE GPS Receiver
SD card with TpmTom One
That's a basic SD compatibility issue. Can you identify the maker of the cards, please? Got backup?
Feb 10, 2008 | Tomtom 1D00.081 GPS Receiver
TT Home does not recognise connection
You definitely need software and maps on an SD card. The TOMTOM will not work without a card inserted. The card will contain MAPS , Map authorisation codes ( to show they are genuine TOMTOM maps bought and paid for ) , POI ( points of interest ), GPS fix data , voices ( for spoken navigation ) etc etc etc. ....................
PLEASE NOTE , TRYING A CARD FROM ANOTHER TOMTOM is very unlikely to work. Each card has an authorisation code that is generated via an algorithm inside each TOMTOM and is device specific.
However , trying a card from another tomtom might produce a diferrent result but still not work , at least this might prove that the tomtom is working OK before you rush out and buy a tomtom card.
Feb 02, 2008 | Tomtom ONE GPS Receiver
TomTom One 2nd edition - Please help!
I experienced the exactly same problem/symptoms with the backup restore function today. After installing the new firmware application on my TomTom Go 510, I did a new backup of my TomTom using the Home Application,  I then attempted to "restore" that backup to two spare SD cards.  The dialog box indicated "restoring," but nothing was being restored. My work-around, which worked great, was to locate the Backup Storage folder on my hard drive, and Drag & Drop its contents onto the spare SD cards (after erasing them).
I'm running the TomTom Home application (v 1.5.106) on an Intel iMac, OSX 10.4.10.
Nov 03, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
52 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
