Question about HP Pavilion dv6000z PC Notebook
Won't boot OS in vista
Hi, 1 - Hp dv6000 Laptop start off and on by itself. 2 - Having Black Window with nothing on it (No Cursor), I can hear the fan is working and 2 or 3 quiet beep and 2 sounds clicking like cd player. 3 - Can takes me hours or days to get through safe mode by using shift+F8 / F8 and then It would takes me to window with safe Mode on the corner) 4 - Can't get to Microsoft Security Essential System by Shift+F10 anymore. 5 - Tried F11 or F12 at earlier time . 6- There is no update in my computer as it says and haven't firwall (Stop working). 7 - Once during repair by myself, Something came up with real time or so. 8 - I have no Recovery disk, No restore point. 9 - I have a file stored in my desktop screen (I THINK it is a back up file) that created by following procedure from 1-2 person from microsoft because I was asking of some failure in updates, and after update my laptop got to this situation and unfortunately MS persons didn't send me as he/she said through the E-Mail and didn't answer my E-Mail anymore. 10- Many other things that I don't remember now and as it is obvious I am computer illiterate . All answer and help appreciated in advance. By the way I went through run>msconfig>System configuration utility > turn the safe boot in off (No safe boot or minimal is selected now). It got worse, Isn't?
  • HP Master
  • 7,627 Answers
FIRST, TRY TO CLEAN THE COMPUTER OF MALWARE, VIRUS..etc. Unplug, remove battery, plug in, Push on/off button with one hand, with the other repeated tap F-8 ,Just F-8, Boot to safe mode with networking, Open Control Panel, Power, Change to High Perrformance, in Advanced Power settings, Change Sleep tand Hibernate to NEVER. Download MALWAREBYTES freeware at : http://www.filehippo.com/download_malwarebytes_anti_malware/ . In the install, UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL SCAN, DELETE ALL RESULTS, REBOOT. IN safe mode with networking, Run a FULL SCAN with YOUR UP-TO-DATE ANTI VIRUS Software, Reboot. If that does not help, post results. OR, You should reinstall Windows, a fresh reinstall. With that many issues, and your skill level, take it to a QUALIFIED Computer Tech. You may have multiple issues, most likely, and all we can do is address one issue at a time. We are at a disadvantage, It's like, "Trying to do surgery, by instructing someone by sending them letters". Any number of Experts on this site could fix the problems quickly, if they had the laptop in their possession.
Posted on Jan 08, 2013
  • 8 more comments
  • nou tali Jan 10, 2013
    Thanks for respond. I can't get rid of black window. It is still turning off and then on by itself. Yesterday I was just trying to tap f8 and there were no luck.
  • max carson
    max carson Jan 10, 2013
    In Windows Vista. Open the Control Panel, open Power Options, select High performance, select Change Plan settings, In the Plugged In, set Turn off display to Never, Put the computer to sleep Never. In Change Advanced Power Settings, Set/Adjust to your preference . HAVE YOU COMPLETED THE SCANS?
  • nou tali Jan 11, 2013
    Hi, I try to tap on f8 and it turn off and on again. I got So mad lol .. and then I hardly hold shift+f8 and somehow i got into the system configuration windows. Thank you. I fill better now. So I followed your procedures up to "Set/Adjust to my preference in Change advaced power setting" I didn't know how to do that. and I just changed the sleep > change sleep after > plugged in to NEVER saved the changes . But couldn't find Hibernate ! I am scaning now. I will let you know after i have done. Thanks A Lotttt.
  • nou tali Jan 21, 2013
    Hi, Max
  • max carson
    max carson Jan 21, 2013
    All is working?
    I was chalenging with the problem in these days. I followed what you said about power option. There is some other problem accured during test. Such az : 1- Laptop keepturning on & off 2- I can't hear beep sounds any more when i turn it on 3- There is no update installed 4- Turn window feature on or off has empty window (after waiting more than enough) 5- Running system file checker tools gave me the answer that win. resource protection could not start the repair SRVC. 6- Don't have recovery CD 7- Can't have access to the internet on Safe Mode 8- Try tot download anti Virus and run it in broken laptop and it didn't go through. 9- No restore point stored that would be usefull 10- Try to Scan with Micro Essen. win. & Malwarebytes and there is no problem on the result. I don't know what else I could do. I am stuck on turn my computer on. I don't have any file on it. But I don't want to leave it with some professional that could go through my hard. If it is possible, I want it to be format as the first day I purchased it.
  • nou tali Jan 22, 2013
    Hi, Max I didn't mean that your tips is wrong. There would be something that I did in wrong way. I didn't have problem after . I just want to let you know .
  • nou tali Jan 26, 2013
    Hi, Max The problem made me to use recovery windows. I still have same problem and have to force to laptop with SHIFT+F8 to could only go through safe mode. F8 didn't work for me. Long story. Now I want to try update winflash. I am now waiting for some CMOS if I am correct. Anyway thanks for your help
  • max carson
    max carson Feb 03, 2013
    Select Safe Mode with Networking to access the internet. Be very, very Cautious if you are considering a BIOS update, if you don't need it it's best to leave it alone, one wrong step, and you have a new "paperweight" , that was a laptop. Have you cleaned the fan, heatsink, and vents? Overheating will cause the machine to shut down.
  • max carson
    You can download a Windows Vista 32 or 64 bit Repair Disk ISO here, burn to disk and get it a try here, I have never used this site, let me know:http://www.windowsreinstall.com/winre/cr...
3 Suggested Answers
SOURCE: New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Posted on Feb 01, 2009
  • 45 Answers
SOURCE: hp pavilion dv6000 won't start!!!
Is your laptop one that is included in the recall/free warranty repair service? Check it here.... there are a LOT of known issues with those HP laptops!!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277&printable=no&encodeUrl=true&
Try checking here and see what you can find.
Posted on Jul 06, 2009
Windows 7 won't boot
Dear user,
Looks like the OS has got corrupted, your system needs a format. before that try pressing F2 to go the window where you get can option to boot from safe mode.
Aug 11, 2012 | Sylvania Computers & Internet
Hp dv6000 will not oot all the way
You've got either a corrupt or missing boot files or system files. You will need a repair disc or a system disc to fix this problem. If you have such a disc put it in the cd drive and boot from it. You want to get to the recovery console so that you can type the following dos command in the black window that appears with white text. The command is: chkdsk /r
Check disk will run well over an hour so be patient. You will also see the percentage of completion going from high to low but that is normal. Just let it run to completion then reboot your machine. Check disk will repair or install corrupt and missing boot and system files. If it does not boot then you will need to reinstall your operating system. Try to a repair install to an existing operating system instead of a new install. The repair install will preserve your data, docs, music, pics and videos. The new install will wipe them out.
Mar 20, 2012 | Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Hp laptop dv6000 won't start how to solve
I think you can try this step and see if it makes your laptop work.
1. Unplug the AC adapter and Remove the Battery
2. Press and Hold the Power Button for 30 secs. without the battery and ac adapter
3. Put it all back in and see if the machine will work.
If happened it doesn't work. Try this.
1. Turn off laptop, unplug laptop, and remove the battery.
2. Unscrew all panels on the back of the laptop.
3. Reseat RAM and Hard Drive.
4. Check if the power port is loosed.
If happens those steps don't work it could be with the Motherboard, CPU, Video Graphics or LCD itself that's having a problem.
Hope it helps somehow.
Apr 25, 2011 | Computers & Internet
Hi am having hp pavilion dv6000 laptop with original window vista operating system ......now its updated with window vista ultimate for that it is asking product key . if i enter this means what the...
if you software is new look for the "product key" printed on the software box,sleeve,carton etc look for the microsioft "hologram" sticker also this is a guarentee your soft is genuine.
Feb 27, 2011 | HP Computers & Internet
My laptap is hp pavillion dv6000 window vista system but i replace dell system .ineed to operate oreginal system
for this u must be having 2 soutions.
1. in the harddisk itself there would be a partition called as the recovery
try recovering your system. it will change the OS original factory settings.
2.u might be provided with an original dvd of your OS. try formatting with it.
Jul 03, 2010 | Microsoft Windows Vista Home Premium with...
Booting problems with acer laptop - no operating system found??
PXE (pronounce Pixie) is an agent used to boot on to the network.
It's using the DHCP protocol to localise a server where the image of the OS is located
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
This can be caused if the hard drive is missing, unplugged or corrupt, or simply by not having the boot order configured correctly.
When you start your laptops, press F2 repeatedly until you enter the bios set up, navigate to the boot order and make sure that the hard drive (sometimes listed as HDD....) at the top of the list.
Hope this helps, let me know if you need anymore help.
Jan 27, 2009 | HP Pavilion dv6000z Notebook
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
Problems with my laptop
I think it has to do with your video cardsettings.I suggest u should get knoppix live cd which is downloadable free from the net.You then try to boot your computer using knoppix cd by changing your boot options to booting from cd.You enter the boot options by pressing down one of the function keys depending on your computer make.If u are able to boot in to knoppix you can access your video card and then resety it.
Jul 14, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z PC Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
