Need owners namual for proper cleaning of tub.
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
SOURCE: cleaning a whirlpool tub
The jets turn yellow from exposure to the sun, not much you can do except replace the jets (costly). What is leaking? if you broke the seal on a jet it will leak and have to be resealed.
SOURCE: i have the the aqualux whirlpool tub, do i
The square filter on the side it tough to get off because of a rubber seal the runs around it. However, once the screw is removed there isn't anything else holding it on. You're going to feel like you're getting ready to break something, but you'll have to work with it to get it off. You might try a flat head screwdriver or a razor and carefully run it between the seal and the tub to loosen it. It will come off, it's just a little bit hard. When you remove it, you'll see why it was so hard to get off...the soapscum is all over the inside of it and some of it hardens around the seal in spots. Hope this helps.
SOURCE: We have a jacuzzi tub
You can find a lot of the old jet trim pieces at US Parts Center or on Bath Parts Plus. Maybe you have already found them but if you are still looking for them. this is a good resource for trim for all bathtubs.
there are two ways to find the trim for your tub. Match up the trim in your tub to what is shown online at their site or email them photos of each part and they will find them for you.
US Parts Center
Testimonial: "Thank you very much! I will contact them. "
