Question about Apache Toys
Replacing broke balance bar and upper blade grippers on YIBOO UJ301 helicopter
Had a crash broke balance bar and upper blade grippers. Also broke hub on inner shaft
SOURCE: MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB.
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Posted on Dec 30, 2009
emissionwiz
  • 76164 Answers
SOURCE: Yiboo AH-64 Gyroscope helicopter. Need to
I am sorry but we have no links to parts sites, my only suggestion is you contact the maker of the Helo.
Posted on Feb 15, 2010
SOURCE: remove and replace balance bar?
Were you able to find a replacement balance bar? I broke mine and can't find one? Thanks!
Posted on Dec 22, 2010
SOURCE: we have a GYROS S107G and when we lift off the
The top of the main shaft is probably broken. There are 2 pins that hold the "head" for the main blades straight and are probably sheared off. This is causing the balance bar to hit the blades and cause it to crash. You could try the crash kit here: http://www.helipal.com/spare-part_v-max-parts_syma-s107.html
Posted on Jan 18, 2011
jyackle5
  • 8197 Answers
SOURCE: The balance bar broke and
May I ask what heli you have so I can help you more. I am a r/c heli piolet and know most helis
Posted on Feb 14, 2011
Need to find out what model of yiboo helicopter this is to find the blade
Measure the length and width of the blade you have and then go on line to the Yiboo Helicopter website and talk to the technicians. Have the helicopter handy if they have other questions..don't forget to ask them for a parts list for your model (You'll need it if you fly it)!
Dec 28, 2012 | Toys
After 3 weeks of perfect flight behavior, my S107 started rocking or pitching back and forth after a crash. The next time I flew it, it was worse, doing a circular "going down the drain" motion....
Sometimes "toilet bowl effect" or TBE can be caused by a crash.
Try this: Gently, but firmly, press (or pull?) the drive shaft down towards the body, where it comes out of the 'copter, and where it comes out of the bottom rotor and attaches to the top rotor. Also, check for any thing wrapped around the shaft. Even a single long hair or thin thread can wrap dozens of times around the shaft and impede its functionality. Balance bar blade strikes are fairly normal in crashes or out of control flying (i.e. heavy throttle trying to pull out of a drop) and not to be very concerned with, they will decrease as you become an even better pilot.
You say "now, after liftoff it just banks sharply and crashes" does it spin? Or maintain heading and just bank? TBE will often get worse, but can usually be fixed.
Charging/Battery care?
Fly. As soon as you can't keep altitude, land and turn helicopter power off. Do not drain battery fully, ever. Cool for 10 mins. Charge until light on USB charger doesn't get brighter when you unplug heli. Cool for 10 mins again. Rinse and repeat.
Please let me know if none of these solves your issue, and I'll consult my repair notes and pick a few brains, we'll figure this one out for ya!
PvT
Jul 26, 2011 | SYMA Toys industrial New Syma S107 Mini...
We have a GYROS S107G and when we lift off the hellicopter immediately starts to lose control and the balancing bar seems to hit the upper blades causing it to crash. Also, the side braces which hold the...
Jan 09, 2011 | xheli Syma S031 Outdoor RC Helicopter
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
How do i get the pin out of balance bar assembly. part of the bar broke of in a crash. i have a new bar.
Where did you get your new balance bar? I have the UJ415 apache and broke the black balance bar off within 10 minutes but can't find a replacement? Thanks!
Sep 12, 2010 | Apache RC Mini Helicopter AH-64
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
Remove and replace balance bar?
Apr 18, 2010 | Apache RC Mini Helicopter AH-64
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
Sep 15, 2009 | RC Toys
Toys Logo
24 people viewed this question
Top Apache Toys Experts
Tom Chichester
Are you an Apache Toy Expert? Answer questions, earn points and help others
