Question about Kenmore Dishwashers
Kenmore ultra wash model # 66513249k900 stock #13249k after installing washer water on power on supply line connected their is no respons. is their a reset button? no lights no function at all. help please
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
SOURCE: Won't Power on!! Help its starting to smell bad
will not start
Posted on Aug 09, 2008
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Posted on Dec 13, 2010
MY PANASONIC WASHING MACHINE ID DEAD NO POWER INDICATION,NO DISPLAY AFTER PRESSING ON/OFF NO RESPONE,BUT WALL OUTLET POWER IS HEALTHY
this is a modern machine and has a digital controller/display
so the low voltage supply circuit usually on the controller board has failed
usualy caused by water or a short or something come loose
check all connections
i feer youll perhaps need to replace the controller board
too be sure of a good lasting repair
this is what i would do then i would fix the older one and return to stock doing any firmware updates to it also
Dec 01, 2014 | Washing Machines
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
Kenmore elite washer model 796.4174 is leaking right below the supply line in the back out of what looks like an overflow valve. Is there such a thing?
The washer usually has 2 water supply line, one for cold and one for hot. You must have connected only one and water is spewing out from the other.
Jan 11, 2014 | Kenmore Washing Machines
Washer not draining
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Nov 20, 2012 | Kenmore HE2 Plus Front Load Washer
Details dimensions of clothes washer for the bleends at the back for ducting porpose.
Factory-supplied
equipment
There is a packet of accessory parts supplied with your washer. Check that all the accessory parts supplied for your model are there. If any parts are missing contact
your dealer immediately.
Inside the drum
Water supply hose for cold water (blue marking).
Water supply hose for hot water (red marking).
Water drain hose.
A bag which contains
Covers to be placed over the holes for the transport bolts (after removing them).
Clamp for drain hose.
Wrench for levelling.
Elbow for attaching the drain hose, e.g. to a sink.
Depending on the type of connection, the following may also be required
Y-connector (can be obtained from any hardware store) in case there is only a cold water
connection available.
Any residual moisture inside the drum is due to the final testing which every washing machine
undergoes before leaving the
factory.
On the rear of the appliance
Power cord with plug.
C = cold water connection
H = hot water connection
Useful tools
The following tools are helpful
Box cutter.
Flat head screwdriver.
Closed wrench (1/2"/13mm).
Bubble level.
Dimensions
a = 27.0 inches (686 mm)
b = 30.7 inches (780 mm) c = 37.0 inches (940 mm) d = 16.0 inches (407 mm)
Door opening angle 180
Approx. weight = 220 lbs (100 kg)
Installation area
DANGER
Never ground the washer to plastic plumbing lines, gas lines or hot water pipes.
Appliance stability is important, otherwise the washing machine could "walk" during the spin
cycles.
The installation area must be solid and even. Soft floor surfaces, such as carpets or surfaces with
foam backing, are not suitable.
If the washing machine is to be installed on a weak wood floor consider the following
0 If possible, place the washing machine in a corner of the room.
0 Screw a water resistant wooden board (at least 3/4" thick) to the floor.
0 Secure the feet of the washing machine with holding brackets. Order the holding brackets (set)
from Siemens Customer
Service (WMZ 2200).
Pedestal Mounting
If mounting the washer on the Siemens pedestal (accessory
no. WZ20395) follow the instructions supplied with the pedestal.
if Install pedestal prior to removing transport bolts.
Closet
If installing the washer in a closet,
observe the minimum distances according to the following table
Minimum Installation Clearances
Closet
Sides 1/4" (6 mm) Top 12" (305 mm)
Rear 2,5" (64 mm) Front 1/4" (6 mm)
Ventilation
Top 48 sq. in (310 sq. cm),
Bottom 24 sq. in (155 sq. cm)
Jan 03, 2011 | Siemens WFXD5200UC Front Load Washer
Have Kenmore top loading washer stock #24771 and it won't fill with water. Checked water lines and not clogged. What else could be the problem?
Other than water lines being clear, faucets turned on, and the strainers are clear (strainers are located right were the hoses connect to the washer), you are looking at a load size switch or a water level sensor failure. A tripped GFI may also be the culprit, as can a tripped circuit breaker.
Both are easily accessible, since they are located in the top part of the washer, in the control panel area.
You might try cycling the load selector switch back and forth, "clean the contacts so to speak". If it starts to work then, you will need a load switch assy soon.
Sears can print you out a diagram of your washer for assembly, and parts. If you have the full model #, you can plug it in at searspartsdirect.com
Sep 21, 2010 | Kenmore Washing Machines
Kenmore Ultra Wash water supply started making loud noise while water is entering washer. If you turn on sink faucet at the same time the noise will stop.
It sounds like the solenoid valves which let in the water are not fully opening and causing chatter -- probably corroded . Turning the washer-water supply faucets down (to the left) will probably stop it, but the solenoid valves need to be checked.
The reason opening the sink faucet stops the noise is that it reduces the water pressure to the washer -- this is the same effect as turning the washer faucets down.
May 05, 2009 | Kenmore Dishwashers
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore dishwasher model 665
check for a clog at the water valve under the dishwasher.Remove lower panel of D/W(dishwasher)Shut off power supply to D/W.Remove the water supply line from your water valve(its most likely mounted underneath to the left side of frame.After removing this ,very slowely turn water back on just enough to determine if you have a clogged line. Let me know when you are there.
May 20, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
88 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
