Question about Troy-Bilt Troy - Bilt Tb120bv Leaf Blowers
How do you remove the impeller on a troy built tb120bv,I've tried removing it cuonterclockwise but the nut is starting to round off
Does the thread set go counterclockwise on the motor shaft ?
  • mike stone Jan 19, 2013
    I looked at it alittle harder and discovered the impeller threads are reversed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Stop and either go buy a Gator Grip socket or take it to a dealer or repair shop
Posted on Jan 16, 2013
5 Suggested Answers
MOTORWIZJ
  • 1338 Answers
SOURCE: my troy-built blower will not start
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
rycgl
  • 1545 Answers
SOURCE: impeller removal
Since the impeller is mounted on the crankshaft and the crankshaft is part of the engine...you're going to have to hold the engine still while you remove it. Do this by removing the engine's spark plug...turning the engine to where the piston is down near bottom of cylynder and stick a length of clean, soft rope or cord in the cylinder. Then, when you try to take the impeller off, the piston will compress the rope into the head (not hurting anything) locking up the engine and allowing you to do the removal.
Posted on Jul 16, 2010
Testimonial: "brilliant, thank you."
  • 640 Answers
SOURCE: ohv motor, has compression but
If there is a simple fix for your problem, it lies in checking valve lash. Any other problem means going into the engine to find. I hope this is helpful for you.
Posted on Aug 19, 2011
SOURCE: Replacing the pull cord on
This is from the tech center at Troy-Bilt.......Take the spark plug out and stuff the plug hole with a piece of rope. I used 3/8 nylon,and stuffed it in until I couldn't get any more in....WA-LA!!!!! A few turns with my ratchet wrnch, and I was on my way to success! A breaker bar would be better if you have one.It will save the gearing
Posted on Aug 29, 2012
Cannot get my 8hp troy built Briggs & Stratton chipper vac to start. I have tried everything! suggestions would be appreciated
Clean the bowl under carb,theirs a nut at the bottom holding it ,pinch your gas line so gas won't come out.remove gas and reinstall.
May 25, 2015 | Troy Heavy Machinery
How to remove impeller assembly from troy bilt shredder model 414?
try pb blaster soke 2 days our more and when you get it off clean up shaft make sure the impeller slides free on shaft then put anti seize on the shaft like troy built should have done
if you can use puller on it if not then air hammer about 20.00 at harbor fright home depot lowes if you have air tank
Feb 25, 2013 | Heavy Machinery
Need to remove the entire head on troy built gas trimmer TB525EC and replace with Ugly head
if by the head you mean the angle drive on the end of the shaft, remove the clamp bolt or locating screw and pull the angle drive off the shaft
and other angle drive with the same shaft dia will fit back on
select an angle drive with a serviceable spool arrangement
May 05, 2017 | Garden
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
I have a 2 cycle Troy-Bilt line trimmer. I've had
Sometimes, unfortunately, the chemicals and solvents used in a "dip" and/or cleaning solution are too harsh. They tend to "swell" the very sensitive check valves inside the carb. The idle fuel circuit has one, the high speed main nozzle has one, and there are one or two inside the primer pase assembly on top of the carb. You state that it won't idle, but does it run otherwise. If it does, some carb adjustments may be required on the L and H screws to get it to idle.
I have stripped my ALKO ride-on mower down to replace the drive belt. However, I cannot get the drive belt over the engine pulley, due to a metal obstruction getting in the way. To det round this, I need...
You will need to take off he main pulley. I did this by knocking in a wood wedge between the drive pulley and the deck and clamping on some molegrips so the pulley did not go round when undoing the nut at the bottom other wise the motor turns, Undo the nut anticlockwise as usual. The pulley assembly then drops down so you can remove the drive belt
Aug 21, 2011 | Garden
How to remove impeller from motor to replace. I 've removed all the bolts but can't remove the impeller from the shaft.
If it's a separate shaft, it requires a puller tool, but first you have to remove a nut that holds the impeller to the shaft. If the shaft is part of the impeller, meaning that it is a one piece fabrication, then there is nothing you can do about it. You haven't even stated where does this impeller come from, a washing machine, a water pump, etc.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
Troy-Bilt Troy - Bilt Tb120bv Leaf Blowers Logo
177 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
