1990 Snyder General Model GUH060A012IN, Fan Motor won't shut off?
Proper operation except Fan Motor runs non-stop
  • 2418 Answers
SOURCE: Compressor keeps trying to start for 5 secs then shuts off
This sounds like the unit is low on freon. From the model plate you have a 24,000 btu unit. This is the minimum needed for 1100 sq ft not accounting for windows and doors. Other factors have to be looked at for a good cooling AC, where is the unit located? In the basement is good. in the attic is bad. look at all the duct work is it all metal and insulated (good) is it plastic tubing (bad). The more insulation on the duct and the better it is sealed the better. You could use more btu's but you would have to replaced the whole system inside and out. You might look for a good 12,000 btu window unit or 2 - 3 8000 btus in different rooms. Now back to the problem I think you unit is low on freon. Should be using R22, unless you have a brother-in-law in the HVAC business you will have to call a local AC company to check out and add freon. Repost if you find other problems.
Posted on May 05, 2010
Testimonial: "Thanks for the help and I will definitely look at getting a window unit. The furnace is in the basement and the duct work is all metal and mostly covered in insulation so I will double check for leaks at the inside unit."
bobicehouse
  • 1524 Answers
SOURCE: Fan will turn if started by hand but soon stops.
Replace fan capacitor.
Posted on Jul 10, 2011
  • 4736 Answers
SOURCE: why does the fan run non stop? the compressor
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Posted on Aug 14, 2011
heatman101
  • 43501 Answers
SOURCE: when air handling unit stops
hi,
The indoor blower squirrel cage or the motor went bad....
Open up the air handler and check the blower... you will find the problem right there...
heatman101
Posted on Aug 21, 2011
canwoodjc
  • 3301 Answers
SOURCE: Radiator fan continues to run. Fan won't shut
Its supposed to keep running even with the car turned off if the car is still to warm, they work off a sensor,, now if it keeps running way to long,, the sensor is bad,, ( if you have to pull the fuse to make it quit after a while,, then check the relay , and then the sensor )
Posted on Sep 02, 2011
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Fan on my hvac split system won't stop running
Hello, sounds like the contactor coil is stuck which keeps sending power to the motor. Change out the contactor.
May 06, 2012 | Heating & Cooling
Subzero 501R fan won't shut down when door closes
HI, I'll be able to help you out but I want to go over some stuff that way you'll have a better understanding of your machine so if I have a question it will easier for you to answer. Lets start out with the fan. The fan your hearing inside the machine is called an evaporator fan. Its located at the top of the machine directly over the evaporator coils, which are behind the back wall, that freon goes through in its gas state to cool the machine. The evaporator coild get cold and the fans job is to pull air from the bottom of the machine, across the coils and intio the refrigerator itself and therefor cooling the whole thing. The fan does not extract air out at all. The suction sound you hear is caused from the machine design and the differential in temperature in and out of the machine. The fan will runs non-stop with only 2 exceptions. First being the door getting opened, which opens the switch, I think on that model is located naer the bottom next to the light switch. If the fan is running after you open the door your door switch is stuck or broken and needs to be fixed, but that wouldnt' tmake the temp raise. The second is when the thermostat registers that its cold enough it shuts the fan off. From the age and what your saying is going on I would first check the condersor coils, located behind the removable grate and see if they are really dirty. That would cause the temp to raise airfloe is blocked and the compressor gets too hot. While down there check the fan to see if its running as that too will cause the machine to get hot if not. Ihe coils are clean and the fan is running call a tech because you probably have a freon leak, which is the likely candidate.
May 03, 2012 | Refrigerators
KithenAid model KUDSo1DL wont operate, clean green light flashes non stop
This is a issue with the way the water is moving & or heating in the unit. There should be a tech mini manual behind the motor kick panel. The manual describs the failure and it's correction. Depending the the model year & run / revision code, this error could be caused by low water level, a bad thermistor, the control board not sensing inputs, bad heater or door interlock switch issues. attached is a couple of help sheets. They are general in scope.
Mar 27, 2012 | KitchenAid Microwave Ovens
Fan doesn't turn on on auto
Sounds like the automatic fan control is not working afc you can take this out it can get cloged with dust on the back of it clean it and see if this works also check your air filter is clean .
Mar 21, 2012 | Dayton Gas Furnace Heater
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
