All the computer they can not recognized it
Not appera in the pc
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings). If your screen does not show this information or if you are unsure, consult your motherboard manual. If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary Otherwise, set as secondary.) Save your settings, and exit the BIOS. I would also be check RAM Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. Once you are certain that the the PC is recognizing the hard drive, replace the side panel.
Hope this helps.
Posted on Jan 09, 2013
Lines screen
screen needs to be replaced. lines will start coming out over and over.
May 07, 2013 | Apple MacBook Pro Laptop Computer with...
Computer powers up, but nothing boots up firewire light goes out. solutions????
Try continually pressing the F8 key as it starts. You may be able to start it in 'safe mode'.
You haven't got a usb flash drive in one of the usb ports, have you? That can sometimes cause the problem you describe.
Any error messages apperaing on the screen? Don't forget the monitor cable ...
Aug 14, 2010 | E-Machines T6520 PC Desktop
When l connect my camera to my PC with a USB cable, nothing happens. l press PC on my camera and it flashes 'one moment' then stops. One moment still apperas on the LCD screen of my camera but nothing is...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 09, 2010 | Olympus FE-210 Digital Camera
Luminance Temperatura
make sure the buttons are not sticking on the lcd screen
Apr 10, 2010 | Dell OptiPlex GX620 PC Desktop
I have a lock symbol apperaed on my laptop and i am not sure what
this could be a read only files. try to save the file on a different filename & locations.
hope this helps
Jul 07, 2009 | Dell Dimension 3000 PC Desktop
Windows will not boot up
Hello.
If you got a Windows CD try the following...
Reboot the computer and enter bios by..
When the blue DELL™ logo appears, press <F2> immediately
You might have to try this a few times since you have to be really quick,
In system setup (bios)
Set CD Drive as first device in the boot sequence. Press F10 then chose "Y" to save.
Reboot.
When asked if you want to start on CD just press any key.
The menu on your cd should have a repair option.
Hope this helps.
Regards...
/Tech5508
Feb 14, 2009 | Dell Dimension 4600 PC Desktop
Computer is not recognizing my memory card
Does your computer recognize any other memory cards? If this is the only card that the computer is not recognizing, I would recommend a new memory card. If your computer is not recognizing any memory cards, I would recommend that you visit the pc manufacturer's web site and download the newest firmware/drivers for the card reader.
Dec 21, 2008 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
David Payne
David Payne
