Need operating manual for american standard thermostat asystat666b
2 Suggested Answers
icemelts
  • 246 Answers
SOURCE: 1 year old system 16
If everything (inside/outside units) is running 'constantly' and you are not getting any cooling there are several things that could be wrong, and I will list them below in the order I think most likely based on the limited knowledge I have about your problem.
1. Often customers will say 'everything' is running when in actuality everything is running with the exception of the 'compressor.' The reason being is that the compressor has an unique running noise which is not easily recognized by the customer. A serviceperson who works on Air Conditioners can pick it (the sound of the compressor) up - simply because they are accustomed to it and it is easily recognized. Therefore, I am unsure whether or not your compressor is running although I do think you inside and outside fan motors are running. All that being said - the fact that you are not getting cooling indicates to me that your compressor is either (A) not running or (B) the system is 'out & or very low' on refrigerant (which will cause the compressor to run very quiet and make it difficult for even an experienced serviceperson to hear it.
Often when encountering systems out of low on refrigerant I've had to actually feel the compressor
(with the system running) to determine whether or not the compressor was running. If you are mechanically inclined and want to determine if your compressor is running - I will just tell you to be very careful when putting your hands in and around electrical components.
One of the things I've done in the past when a little hesitant to actually touch the compressor (with system running) but still wanting to know if it (compressor) is running is to take a long screwdriver and hold the tip to the compressor - therefore being able to pick up the vibration of the compressor (which is out of gas or very low). If you do this and feel the vibration of the compressor and then know that it's running you have the infomation needed to understand that your system is either out of or very low on refrigerant.
If, however, you determine that the compressor 'is not' running I would bet that when you TURN THE SYSTEM OFF AND MAKE SURE ALL POWER IS OFF - and hold your hand on the compressor it will be very warm/very hot - which indicates that it has heated up and went 'off' on internal overload. You could still be experiencing the problem - of lack of refrigerant - because when the refrigerant level is low the compressor 'will' heat up.
However, is also possible (and more likely) that the compressor is 'off and hot' because it has broken down 'electrically' which can be caused by various factors - chief of which is - it is mechanically/electrically wore out and needs replacing. Note: it's also possible, although unlikely, that you have a bad 'run capacitor.' I would take a look at it (it's a gray or silver oblong shape electrical device with wires attached to it) and see if it's 'bulged' in any way - which is an obvious sign that it's bad. Barring a 'bulge' I would assume the capacitor is ok - which it probably is.
At this point and with the above indications - I would think you'd need an experienced serviceperson to look at your system.
2. But - 'it's also possible that when you actually turn the system off - MAKE SURE ALL POWER IS OFF -and feel of the compressor it "could be cool/cold' to the touch. If' that is the case - then I would look for a 'wire burnt off it's connection' (somewhere in the unit), bearing in mind that the obvious place for this to be will be on the compressor itself.
You will have wires running to the compressor and will be behind a little black plastic cover held on by a silver wire clamp. Remove the clamp - pull the plastic cover out - and examine the connections under it - looking for a wire that is burnt off. Move the wires a little because often the wire will be burnt off but it will not look like it - and by moving the wire you will see that it is not connected. If you find a wire burnt off - then you just need to get a new connector and connect it back on the wire and put the connector back on it's connection and you 'should' be fine.
A wire being burnt off a connection at the compressor 'could be' a sign of something seriously wrong with your system but 'usually' you can repair the wire and the unit will be ok. Maybe the connection had been 'loose' from the factory and finally burnt into or etc etc. But, as stated - to could be an indicator of something else. The only thing you can do is to repair it and hope for the best.
Note - obviously - you would want to have a 'wire burnt off' instead of all the other stuff, i.e. 'out or low' on refrigerant,' or a 'compressor mechanically/electrically wearing out.'
Hope this has helped.
Posted on Jun 10, 2011
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
American standard error code 158
thermostat error codes for an american standard ... - AllExperts
en.allexperts.com > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
HOW DO YOU CHange battery on american standard thermostat?
THERMOSTAT SHOULD SNAP OFF BASE AND YOU SHOULD SEE BATT COMPARTMENT IF YOU HAVE G WIRE ON T STAT DONT NEED BATTS ANYWAY .ONLY NEED BATTS IF NO G WIRE AT T STAT .
Aug 18, 2014 | American Standard Heating & Cooling
Standard reset
You are out of freon or the thermostat is broken sounds like
Jul 10, 2013 | American Standard Heating & Cooling
My American Standard AC fan runs continuosly
Hello my name is Heath it will be my pleasure to assist you. Try turning the fan switch on the thermostat from on to auto and see if the fan shuts off.
Aug 28, 2011 | American Standard Heating & Cooling
Gmail.comAccording to American Standard's website it says to contact a local dealer in order to obtain a manual for my thermostat, it is a Gold ZM Control. Can you provide me with a manual or tell me...
Who makes the thermostat? Most companies have an online site in which you type in the thermostat model and associated numbers and it gives you the thermostat operating procedures. Look for the manufacturer on the t-stat and go from there. Every t-stat is different as far as programming so you do need the instruction booklet.
Aug 03, 2011 | American Standard Heating & Cooling
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Wiring thermostat to a American Standard 5ton air handler I don't have the schematics Model twe6a300ab serial# e23176168 year 6-1990
On the thermosta there are terminals, what you need to do is look at the old thermostat that you are replacing and make a note to yourself; what color of wire goes to which terminals,, Rc, R, C, G, W, Y, O, ect.
This is because the installer can use any color of wire. Then just hook the wires up to the same lettered terminals. American Standard should be standard terminal setup.
Mar 09, 2010 | Heating & Cooling
Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
