Question about Tomtom ONE GPS Receiver
Memory card in TT one XL-S
When I install my 2g sd card in my TT it just comes up with a screen that shows the TT unit with the sd card being removed and then it shows the sd card beside the unit with a red X over the card. I dont know it its saying not to remove the card or if its saying it has a problem with the card. I have heard that the TT One has to copy all info to the card but I have let it flash the image of the red X over the card for an hour and a half now can anyone help
  • Anonymous Jan 23, 2009
    Mine turns on and show the sd card screen but when i insert the card it puts a red x over it
Sync one xl with tomtom home on your computer making sure the card is not inserted do a backup of your one xl, once you have backed up device disconnect from your computer. insert memory card reconnect device to computer and sync with tomtom home do a restore and hey presto card is recognized
Posted on Feb 08, 2009
  • 515 Answers
2 Suggested Answers
  • 6 Answers
SOURCE: when I install my 2g
dude check it the tomtom needs an application, map, and at least one voice to work so before u start u need to formatt ur sd card to fatt 32 once u do that go to tomtom home and just update ur device an application and a ton of voices will come up grab the application and ONE voice now for the bad news when it comes to the map its a pain because they are kinda strict to be honest call tomtom support for help with the map they will walk u thru takin the map off the original sd card puttin it on the desktop then movin it to ur new sd card however sometimes there is issues wit the certifacation file this again is wher e u need tech support... use to wrk for tomtom....
Posted on Jan 21, 2009
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When turns on shows a computer screen and red cross
Go to TomTom Home reconnect and then go to device on the tool bar. Select disconnect device and this should free up your device and take the red X off.
Goodluck,
Please don't forget to rate my solution
Apr 26, 2008 | Tomtom ONE GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Unable to download map onto tomtom one xl
If you have an older tt xl it will only take up to a 2gb sd card. Larger than that you will get errors.
Hope this helps
May 30, 2009 | Tomtom ONE GPS Receiver
Download maps to SD but TomTom won't read them
The OneXL can't read form internal memory and SD card at the same time.. much like a floppy disk on a computer. If it shall boot from SD card, it need the software installed as well...
May 05, 2009 | Tomtom ONE XL GPS
TomTom One series 30 won't reset
It sounds like you have lost the operating system or the flash memory card has gone bad. Make sure your unit is fully charged and try again. Then connect your device to your computer. If it comes up in my computer right click the drive and check properties to see how much space is availiable on the drive. If it says 0 the flash has gone bad, I have a 20 series tt that this happened to. My solution was to insert a sd card (at least 2 gb.) into the sd card slot found under the sticker no sd card requaired on the bottom of the tt. TT home then installed the operating system but the downside is if you have not made a backup od your tt you will have to buy new maps (not cheap).
Hope this helps
Apr 23, 2009 | Tomtom One XL GPS Receiver
Tom tom Western european map
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
Feb 24, 2009 | Tomtom One XL GPS Receiver
When I install my 2g sd card in my TT it just comes up with a screen that shows the TT unit with the sd card being removed and then it shows the sd card beside the unit with a red X over the card. I dont...
Jan 20, 2009 | Tomtom ONE GPS Receiver
SD card for TT one XL
Card needs to formatted using fat32 in windows formatting options, then copy and paste your back-up files one by one to your new card.
Hope this helps
Oct 16, 2008 | Tomtom One XL GPS Receiver
TomTom One 2nd edition - Please help!
I experienced the exactly same problem/symptoms with the backup restore function today. After installing the new firmware application on my TomTom Go 510, I did a new backup of my TomTom using the Home Application,  I then attempted to "restore" that backup to two spare SD cards.  The dialog box indicated "restoring," but nothing was being restored. My work-around, which worked great, was to locate the Backup Storage folder on my hard drive, and Drag & Drop its contents onto the spare SD cards (after erasing them).
I'm running the TomTom Home application (v 1.5.106) on an Intel iMac, OSX 10.4.10.
Nov 03, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
196 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
