Question about Packard Bell Computers & Internet
There is a light on all the time like sound sighn and battery goes down very fast
NOT SURE WHAT ELES I CAN TELL YOU
  • Packard Bell Master
  • 7,627 Answers
How old is the battery?
Posted on Jan 08, 2013
The battery has been replaced but the battery still loses power and runs down once its turned off
it sounds like you have somthing staying powered up hook up battery negitive cable and then use test light on positive lead put clamp on battery positive lead and use the point on the battery if light is on bright then you have somthing staying on like glove light dome lights or even visor lights with lead still hooked up you need to touch the clamp to the point end to power down the timer system usually 20 seconds then pull clamp away from point end while staying connected with battery and cable if you loose that connection you will need to start timer power down again then while someone is keeping the connection pull one fuse at a time and notice if light goes out or dim if it does either then see what that fuse powers and it will tell you what is staying powered
Aug 17, 2013 | 1999 Ford Explorer
BATTERY GOING DOWN TO FAST AND A LIGHT ON ALL THE TIME LOOKS LIKE A SOUND SIGHN
How old is the battery? "A LIGHT ON ALL THE TIME LOOKS LIKE A SOUND SIGHN"? Can you explain?
Jan 08, 2013 | Computers & Internet
The brake lights came on with abs brake pedel is very rough and doesnt goes down all the way and took it to repair shop and told us it the turbo booster .
go to some on eles and have them scan it. but i thank your abs pump is bad or its brain. also brake booster can cause the pedal to be hard if it is bad you should be able to hear a hissing sound in side the car when you push the pedal
Feb 05, 2011 | Chevrolet Cavalier Cars & Trucks
I have a 97 BMW 528i... When I put the key in the ignition the lights on the panel blinks real fast and the car makes clicking noises. The car doesn't even start. And from time to time the car alarm goes...
Check your battery. Check to make sure that the computer under the hood in the front dash is dry and properly connected. Another common failure of the alarm system are the door latches. (the latches have a micro switch in them that tell the system when the doors are shut)
Jan 20, 2011 | 1 Series Vehicle Alarm System
I HAVE A NEW SHOPRIDER SCOOTIE 4 WHEELS . I CHARGE THE BATTERY AND HAS A BEEPING NOISE . IT WONT RUN AT ALL. LOOKING AT THE BATTERY POWER LIGHT AND IT DRAINS FAST
Rickie If you count the number of beeps (4 beeps pause 4 beeps etc) this could tell you what error you are having. If it justs beeps with no pattern and your battery lights run down very fast then I think the batteries are one problem. Also check your charger to make sure that you are getting the correct voltage to your Batteries. You might want to ask a tech to check out the charger Hope this helps you
Oct 01, 2010 | Health & Beauty
85 mr2 check engine light on
I would start by performing tune up. Change the sparkplugs and wires, and change the air filter.
Check the timing of the engine. Make sure the timing is correct (please check the green book for the correct timing...)
In my experience, it sounds like you have a bad oxygen sensor. Replace this sensor, then keep the battery disconnected for at least 30 minutes, then reconnect the battery and drive the car through it's paces (stop and go, acceleration, cruising, etc...).
Disconnectingthe battery will cause the ECU to reset, then driving around will cause the ECU to once again reprogram itself as necessary.
When the oxygen sensor goes bad in these models, it tends to make the car run with too much fuel, although sometimes too lean, and it tends to overheat the engine.
Apr 04, 2009 | 1985 Toyota MR2
02 Denali won't start
tell her to not use the radio at lunch ..she is draining the battery...replace battery..recommend gel type with deep cycle rating highest you will afford and if she must ..run engine at lunch time to charge system
Oct 09, 2008 | 2002 GMC Yukon Denali
Find about samsung x05
sound driver problem
Sep 04, 2008 | Samsung X05 Notebook
The battery life is very short
decrease its brightness form the settings to 50% the battery gives more backup....or if u hear the songs through the speaker for long time the battery goes down fast & this prob with each & every set ...
Aug 03, 2008 | Sony Ericsson K800i Cellular Phone
Computers & Internet Logo
14 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
