Question about Hoover V1 SteamVac SpinScrub Vacuum
Brushes don't turn anymore
There already was the same problem asked and I read the answer and I had already been trying to take the bottom over off and couldn't figure out how. The other person wrote back and said they couldn't figure out how to get it off either. There was no response printed for him. My vac is a hoover F5906-900 How do you get it off. Thank you
This is an update from my last post. There are a bunch of people with this problem. The first thing is to check the little slide out lint trap on the bottom (red on my machine). If this is clogged the brushes won't spin--so I've heard. Check these websites www.mendmy.com/answers.php?id=24062 and for the part schematic for the machine If your machine is different you can specify a search to get a diagram of the correct one. www.vacshopusa.com/f7425.htm Good Luck!
Posted on Jul 02, 2007
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Hoover F5906-900 Steam Vac
Make sure that that the lid for the dirty water tank is locked on to the bucket, the other is make sure that the filter on the inside of the lid is not all the way up, needs to be a gap 1/4 inch or so.
Posted on Jan 06, 2008
  • 126 Answers
SOURCE: brushes
This machine has no belts. There is an air driven turbine that propels the brushes. If you look under the little glass window at the left front corner of the machine, there is an intake screen just above the indicator dial. That screen is there to keep debris from entering the turbine and will have to be kept clean. If it is clogged, then the turbine will not function.It is also possible that moisture has entered the turbine and siezed the bearings. If that is the case, the turbine would have to be replaced. Also, because this turbine works off the suction of the motor, if the recovery tank lid is not on correctly, then the suction loss will effect the brushes. Check the lid and make sure it is on right.
Posted on Jan 13, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
How to change Brushes on Kirby g6
you take off the front assembly, un-clip the bottom assembly where the brushes are and there are 3 different heights of the brushes just rotate it and continue to use unless you have already used all 3 sides, I, II, III are the options make sure both sides are on the same, refit back into assembly and make sure you clip the bottom back together and them replace back on to machine
Jun 24, 2014 | Kirby Heritage II Vacuum
Just purchased the Max Extract 77 from Wal-Mart. We used it and the brushes would not turn. Called the 800 number and they could not help us. He stated we could take it to a repair shop or return it to...
Please read the back of your receipt.
I believe you have something like 15 or 30 days to return this type of item.
They have a fantastic return policy as long as you have the receipt, and make sure the stuff is back in the original box, and all the accessories are with it.
As soon as you walk in, a nice smiling lady will place a sticker on the item and point you to the Returns Desk.
That's it.
You will be refunded in the same manner you paid for it.
NB. Don't complain, and don't get too eager giving out unsolicited information.
When asked why you're returning it, answer: I does not work.
If asked what doen't work, answer: The brushes don't move or watever short answer is appropriate.
Jun 30, 2011 | Hoover F6055-900 SteamVac Maxextract LS...
On the white roomba 530 - does not fill big dust cup anymore
you may need to clean the ends of the roller brushes.pull both out pull off the funny looking yellow ends and clean out hair ect.
Jul 03, 2010 | iRobot Roomba 530 Robotic Vacuum
Need to remove bottom brushes of Hoover Steam cleaner F7452900 to clean
Here is the manual that came with the vacuum if you didn't have it already, in it on page 13 of the pdf shows you how to remove the bottom brushes.
www.thinkvacuums.com/pdf/uprights/Hoover_F7452900.pdf
Aug 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
I NOTICED SPARKS INSIDE THE UNIT WHERE THE HANDLE ATTACHES TO THE MOTOR....NOW IT IS NOT WORKING WHAT CAN THIS BE?
DO NOT TRY TO TURN THE KIRBY ON ANYMORE BEFORE YOU GET THIS REPAIRED!!! Your Kirby needs carbon brushes and if you don't already need a new armature, the worn out brushes will destroy the armature that you have. Here is a guide that will help you get down to the carbon brushes to change them...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
It is a guide to replace the power switch, but will give you the step-by-step to get down to the carbon brushes.
Hope this helps,
Marci
Jun 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Need help!!!!!
Need help!!!!!
Hoover F7425-900 SteamVac V2 Widepath Upright
I read the manual and tried my new Hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You could have a bad water release valve on your water tank of which holds the water, the trigger assm might not be connected, bent or broken. Check the trouble shooting owners manual --- also there are hoses that could be crimped or bent, or clogged or not connected, but it is my guess it is the water release valve. Try to back track the water from the holding tank and test all the valves on the system and you might find the problem by the process of elimination. Feel free to contact you local vacuum cleaner dealer in the yellow pages or contact the Hoover Co @ the information listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
I have the steam vac spinscrub upright. The brushes won't spin anymore.
Have you checked the lint screen? Your brushes are air driven if it's a Hoover Spin Scrub. There is a clear cover on the left side, when facinf from front. Remove this cover, about 3x5 inches and tapered, and clean the screen. Some units have a red or white screen that you can pull out from the bottom of the unit, left side just behind the brush block. Clean the screen then reinstall. Check that recovery tank is properly positioned- lack of seal means less suction which translates to brush block not turning.
Apr 16, 2008 | Vacuums
Hoover V1 SteamVac SpinScrub Vacuum Logo
57 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
