Question about Systemax Venture HU B560 (988799) PC Desktop
Need to reset the bios
I have a Systemax venture and i set it to fail safe in the bios and it stop monitoring all the ports and i had a password on the bios. so i toke my computer cover off and pulled the batter out thinking it will help and now when it restarts it make a lot of beeps and then makes a loud greeddan sound and i still cant see any hing.
    Scholar:
  • 54 Answers
When you pull out the CMOS battery make sure to unplug the PC and press the power button 3 or 4 times to ensure any residual power in the capacitors are discharged. If the problem persists you may need to remove and re-seat the CPU, Memory and/or video card to check for a loose connection.
Also inspect the capacitors on the motherboard for any visible damage like buldging or leaking capacitors, if you see any likely the motherboard is bad.
Posted on Jan 20, 2009
What keys access the bios on systemax venture vx2
Usually, when you boot a machine, the bottom of the screen briefly displays what function key you need to press to access "setup" (or BIOS). See if this info helps...
http://pcsupport.about.com/od/fixtheproblem/a/biosaccess_pc.htm
Jun 21, 2014 | Systemax Venture VX2 Intel Core2 Quad...
HOW TO RESET A BIOS PASSWORD
if its a dell contact support they can reset that if its a ibm your screwed .sorry any other bios password as long as boot up is not requiring a password you should only be limited to changing settings not the use of the laptop
Mar 01, 2013 | Systemax SYX Venture Mobile XVI.B Notebook...
How do I update computer bios
Hiyou do not need to update the bios of your computer (systemax desktop pc ) because the current version of your bios is still up to date. If you are having a problem and you want your computer bios default all you need to do is to remove the cmos battery for 1 minute just to be sure because the standard wait time is only 30 sec. put it back after 1 minute. automatically the bios will be back to default settings
May 13, 2012 | Systemax Venture PC Desktop
How do I enter into BIOS on a Systemax SYS651M03 pc? Windows XP will not start and I need to change the boot sequence to boot from CD, but can't find the right key to open BIOS on startup.
Usually delete, might be f2, to enter the boot order I gauruntee it's f12. If the bios is passworded, you are screwed. Try reseting the bios by unplugging the unit, remove the bios battery for atleast 10 secs, then put it back. If it's still passworded...see above.
Apr 16, 2011 | Systemax (036052) PC Desktop
In CMOS setip utility, I am not able to load fail safe or optimized defaults or set supivisor password.
Try opening up your computer and removing the CMOS battery. Should be the only battery on your motherboard (the thing everything plugs into) this will usually reset your bios. Some bios also have a jumper that needs to be switched but without knowing your motherboard model I can't be sure.
Mar 01, 2011 | Systemax Ascent PC Desktop
Hi, I would like to know how to safely factory restore my Systemax Venture, and would be glad if you could give me step by step instructions to follow. Thanks!
Only with he restore disk and manual. Or download all software and driver from their site have a official windows cd inlc. license code and reinstall windows ans drivers. Put win cd in tray and reboot (change bios if needed to boot from cd). Install windows, install al drivers.
Jan 12, 2011 | Systemax (036052) PC Desktop
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
Pc does not go beyond Lsass.exe application error
Try getting into safe mode, by taping the f7 or f8 key before it boots. Once in safe mode we can do a restore to the last restore point, and go from there. If you can't get into safe mode, let me know and we will go into the bios, set the machine to boot from the dvd drive and use your xp disk to boot her up, this method id too much to post here, let me know and we will take it up only if needed. Also try this, turn off any user accounts that the computer has installed other than your administrator account, and let me know what happens
Dec 15, 2008 | Systemax Venture PC Desktop
I tried to add memory ram to my computer, but it was not compatible and now my computer does not start. the monitor only shows me a "CMOS ERROR" AND warn me that my CPU has been changed or the...
if you put your old memory in and boot into bios setup and go to default or fail safe settings that should work then get the right memory that u need and install as usual
Aug 20, 2008 | Systemax Computers & Internet
Systemax Venture HU B560 (988799) PC Desktop Logo
285 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Mike
Victorman
Victorman
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
