Question about Husqvarna Rose
I am trying to "select" an embroidery on the stitch panel. How is this done?
  • Husqvarna Master
  • 1,564 Answers
Try looking in your manuals. That's what I would do.
Posted on Jan 09, 2013
My sewing machine will not make decorative stitches?
Is it an embroidery only machine. Typically embroidery is done with the needle in a fixed position while the hoop is moved around.
Jan 05, 2017 | Husqvarna Sewing Machines
Embroidery stitches to far apart
1. To make changes on a computer there is a method to increase or decrease the size of the embroidery (usually two buttons pushed simultaneously). This will resize the embroidery and compute a new number of stitches. If you have resized it in the past without utilizing this feature the number of stitches will be wrong and will make an embroidery that has problems.
2. The embroidery program that you are using may have a problem. This can be checked by trying other embroidery programs.
Oct 01, 2016 | Brother Sewing Machines
Why won't it do decorative stitches?
Have you selected the proper stitch. Look at the decorative stitch line 1,2,3,or 4, then the number above the stitch. Your screen should say 1:24 for line one, stitch 24. Make sure you are using the recommended foot. Embroidery unit is disengaged. Then makes sure you have selected the proper weave or thickness of material button. If it still won't sew, try a different type of fabric button and try that. This will change the tension. The tension could be too tight or too loose for that stitch.
Sep 08, 2014 | Sewing Machines
Janome MC11000 how do you realign your embroidery unit. When doing applique the satin stitches do not cover the tackdown stitches. I've tried several designs, all by quality digitizers and all the...
P, attern is from monster knits for little monsters. I'm attempting to do the little piggy on page 24. It a pull over hat with a neck ruff.
Dec 05, 2013 | Sewing Machines
How to stich embroidery
That would depend on if you have a regular home sewing machine or a embroidery machine. I'm going to assume that you have a regular machine.
There is something called free hand embroidery. you lower or disengage the feed dogs, take off the presser foot. Some use a darning foot and others just leave the foot off. Hopefully your design is already marked on the fabric. Place fabric in a regular hand embroidery so they fabric is right side up but the hoop makes it sit down in the rings. (make sense) Fit your hoop on the bed of the sewing machine, under the presser foot/presser foot bar. Lower the presser foot lever. (important for tension) and select stitch style and length. you may need to adjust tensions too.
Begin stitching, take a couple stitches... then reverse a couple... then snip the loose ends. Continue to stitch, guiding the hoop so that the needle follows the design. Start slowly and as you discover how your hand movements effect the length of the stitches... you can speed up and slow down as you need to create your design.
https://www.youtube.com/watch?v=ylMy6QdsZr4
Nov 03, 2012 | Sewing Machines
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I am trying to figure out how to monogram. I keep having trouble adjusting my machine.
For doing a manual monogram (by hand, not using embroidery unit) Follow these steps.
1. Put on the "N" foot ( This is your open toe foot, so you can see easier)
2. Select the zig zag stitch (Should be #4, right next to the straight stitch)
3. Hit the stitch adjustment button on the screen ( Lower left)
4. Set the width (Will have a zig zag "/\/\/\/" icon) to whatever size you would like (Usually 4.0mm to7mm)
5. Set the length (will have a line "---------" icon) to a very short setting
You're now setup for a monogram. You might like this video too for using your embroidery unit.
Let me know if you have any more questions,
Chris
Jun 07, 2010 | Baby Lock Ellure
I need the cd that teaches you how to use the brother pe150v embroidery machine do u know where to buy please? Thank you.
You will have to contact a Brother dealer to see if they can get a DVD for you.
The operation of this model is very straight forward, if you need a manual, you can download a free one here - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=PE150V
You can also find free tips and tutorials at http://www.embrloderylibrary.com
The easiest way to learn how to use this machine is to gather your supplies: embroidery thread (choose a few basic colors), machine embroidery bobbin thread (important to use this and not the top thread), medium weight cut away stabilizer and scraps of fabric.
Open the manual right next to the embroidery machine.
Read and follow each step.
Hoop the fabric and stabilizer and then stitch out a few of the built-in designs. The select a frame and stitch that around the design. Bump up the position of what you have stitched out and select a few letters to put under it.
It may not be perfect the first time, but if you keep playing you will soon be very proficient.
If you need more assistance as you learn, visit on-line embroidery forums such as Ann The Gran or SewForum.
Relax and enjoy a great craft.
Mar 02, 2010 | Brother PE-150V Computerized Sewing...
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Sewing Machines Logo
16 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
