Question about Toshiba DC-SB1 Remote Control
Program my toshiba DC-SB1 remote to tune in Antenna Channels
Use remoter on HDTV channels
cammykins
  • 149 Answers
SOURCE: Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Posted on Sep 24, 2007
SOURCE: Toshiba Remote #CT-847
where can I get the manual for a Toshiba ct-847 remote
Posted on Jul 31, 2009
jyackle5
  • 8197 Answers
SOURCE: I have lost the manuel
You can learn how to program the remote on the link below page 12
http://tacpservice.toshiba.com/consumerproductsupport/manuals/tv/2004/32A14.pdf
Good Luck
Posted on Dec 07, 2010
  • 8457 Answers
SOURCE: My Toshiba Remote Control won't
Take the dawn thing aparts.Take some Q tips dipping it in with some rubbing alchahols.Clean the PCB board and the - + battery connections.Wait like 20 mins put the remote control back together again.The thing should work now.If not the CPU probally is shorted and dead,remotes devices are heavy depend on it CPU chip.Try website Remotes.com to buy an exact or very colose to the original remote.
Posted on Dec 10, 2010
  • 3 Answers
SOURCE: I have a hugh, older
If you only want to control the volume and channels, then a "Oneforall" remote will work. If you want to sell the toshiba vc-661T remote, email me. mike49309@hotmail.com
Posted on Sep 25, 2011
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
Hello
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
OK.
Jul 19, 2011 | Toshiba DC-SB1 Remote Control
I have got a new Toshiba Regza I have tuned it in but don't seem to have got all the channels can u help
you will need first to configure the antenna sources where you want to program channels. and then you can add channel through your remote control. to add channels in the channel memory, first press MENU and open the set up menu and then highlight installation and press enter. a new set of installation menu icons will appear on the screen. open the terrestrial menu highlight channel add, and then press enter. the list of channel program from the antenna source that you select will appear on the screen. to add now a channels to the channel memory, highlight unchecked box next to the channel number you want to add, and then press enter to check the box.to save new settings highlight done and press enter.
Apr 19, 2011 | Toshiba Televison & Video
How do i tune it?
If by tune, you mean program channels;
Press the menu button on the remote and select the Setup option.
Go to Installation, Terrestrial, Channel program, start.
This will automatically add all the channels to your television that you are able to recieve.
Mar 05, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I just got a Toshiba HDTV 40RV525R and don't have a remote or owners manual. I have it set on channel 3, but don't know how to get any other channels? Can I move to another channel without a remote? ...
Yes you can if you have a signal hooked directly to the tvs antenna input. On the side of the tv you have some buttons including menu, volume which act as left and right while you're in a menu, channel which are up and down while in a menu. So, press menu and you should see a menu on the screen.Open the terrestial menu then input configuration and choose either cable or antenna to match what you connected to the tv. then select done to put that in memory. Open the menu aagin, go to set up then installation, then terrestial, then channel program and select start. The tv will start changing channels and will put in memory any channel it finds while searching. After this is done you can use the channel up and down buttons to scroll through all the channels.
Dec 05, 2009 | Toshiba 19LV505 DVD Player
No access to channels over 37 (Not a cable provider problem)
try to autotune manually there should be a menu button on tv hit thta then go to channels then hit auto program..make sure u have cable selected as the input not air/antenna
May 25, 2009 | Hitachi CLU-5713TSI Remote Control
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Toshiba 2141tb tuning
there is a menu that has autoprogram in it, use that and itll scan all channels and memorize the viewable ones. Sometimes it is a stand alone button behind a door or it is in the setup menu. Make sure your antenna is plugged in. If you have cable, the only channel that may be stored is 3.
Mar 03, 2008 | Televison & Video
Toshiba DC-SB1 Remote Control Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
