Question about Ravensburger Toys
Where to put batteries on chugga choo choo - Ravensburger Toys
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Apr 06, 2012 | Peg Perego Choo Choo Express Train Set
Our choo choo express train won't start...is it the battery...how can i fix the battery that has charged at least 24 hours
check the battery and the charger with a multimeter and make sure that its putting out at least 6 volts
Nov 07, 2010 | Peg Perego Santa Fe Express Ride On Train
Motor will not run?
sounds run off of 3 aaa batteries, motor runs from the 6volt sla battery under the seat, probably needs to be recharged
May 15, 2010 | Peg Perego Choo Choo Express Train Set
95 jeep wrangler making tractor/old tyme car sound
It sounds like you have a bad valve or a cylinder isn't firing. Pull the spark plugs and check them for deposits and clean, regap or replace. Do a compression check of the cylinders to determine if you have a problem with a valve.
Nov 30, 2009 | 1995 Jeep Wrangler
Yes, is Auto Trans.
Smoking like a choo choo train?
Jul 10, 2009 | 1985 Toyota Celica Supra
2003 VW BEETLE Won't Start....
check fuel pump if not fuel pump then have ecm check aka the computer
Jun 25, 2009 | 2003 Volkswagen New Beetle Convertible
;94 Taurus cranks but won't start
HAVE YOU TRIED CHECKING THE FIRING ORDER AND SOME TIMES YOU HAVE TO TAKE THE CAPS OF THE SPARK PLUGS
May 07, 2009 | 1994 Ford Taurus
Toys Logo
22 people viewed this question
Top Ravensburger Toys Experts
PhantomLib
Level 1 Expert
Tom Chichester
Are you a Ravensburger Toy Expert? Answer questions, earn points and help others
