Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Removing beater bar from Hoover canister vac sweeper head
  • libjackyl Jan 08, 2013
    I can't get the dang thing off to replace my drive belt. I'm sure it's a simple solution but I can't figure it out.
  • Hoover Master
  • 18,424 Answers
Click here > http://hoover.com/file/402/ for the manual it will give you full instruction on belt change on page 7
Posted on Jan 08, 2013
  • 126 Answers
SOURCE: hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Posted on Jan 20, 2008
Kazong
  • 152 Answers
SOURCE: hoover elite belt change model number U4245
real simple you have to articulate the belt a little sideways and the belt should slide right between the pulley and the plastic.
Hope this helps.
Posted on Feb 06, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Posted on Mar 22, 2008
SOURCE: Hoover Beater bar belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=744864
Posted by rubyspider on Jul 05, 2008
I need help installing the beater bar belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 WindTunnel. All you need to do id to remove the bottom plate by removing either the screws, clips or levers and the bottom plate should come right off, and then you can get @ the belt – if not then the top cover will come off and then you can serv it from the top if needed. Then you can lift up the one end of the Hoover brushroll and then slide the new belt on to the pulley side of the brushroll and then use a belt puller or a screwdriver with a hook on the end and then pull the belt onto the motor pulley. Then track the belt in a straight line. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 07, 2008
dragonsthatk
  • 547 Answers
SOURCE: hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Posted on Feb 12, 2009
Kenmore canister power head not working?
Without more info, I would investigate the drive belt, make sure the beater bar is free to spin (no hair or carpet fibers twisted onto the moving parts), and then check that the power is getting to the motor of the power head. Most often it is hair/fibers that collect around the ends of the beater bar. This causes the belt to stall, heat up and stretch due to the drive motor shaft spinning on one spot because the belt can't move. After removing twisted hair/fibers, you probably only need to replace the belt.
Aug 08, 2014 | Kenmore 25614 / 25615 Progressive Bagged...
Sh40060 canister hoover vac beater bar moter has no power
replace it can be gotten at guarantee vacuum and sewing center and will only cost about 25 to 30 dollars
Mar 17, 2014 | Hoover U5194-900 Mach5 Multi-Chamber...
Beater bar on aerus electrolux ambassador canister vac has stopped working.
Beater bar failures are quite common in vacuums, Electrolux is no exception.
Apr 17, 2017 | Vacuums
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Vac wont pull/**** anything while we try to vac floor,
Hello RonD30,
If you are getting suction thru the hose and not from the bottom section.. you have a clog somewhere inline with the base area... If you have access to a shop vac ... unplug the Hoover, open up the base and remove the beater bar /belt assembly.. then hold the shop vac nozzle on the point of entry to where the Hoover pulls the debris into the dirt compartment. I am fairly certain you have a clog somewhere in that ducting.. Stubborn ones may need a little motivation.. so you may be able to get an electricians snake or metal coat hanger bent to release the jam..
Hope that helps..
Regards,
Rick..
And you are right , regarding Lowes..but don't exclude Home Depot from the same rating..LOL Once the sale is done.. so are they...
Dec 13, 2008 | Hoover Vacuums
S3765
Returned the sweeper to Costco for a full refund and bought another.
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
LOUD NOISE FROM HOOVER POWERMAX ii
These vacs can stop up in almost inaccessible places. That sound means that it has stopped up somewhere and the electric motor is in a strain. Keep it running like that long enough and the motor is toast. I have one that seems to prefer the hose area where it goes by the motor and into the bag. The tube from the motor to the bag also is prone to stop up. To take these apart requires that you start at the beater bar area and work you way inward. In certain areas if you look closely, you'll see little arrows pointing to the screws. These are the ones that will allow you to get closer to the innards of these. When you get to where the motor is, look for blockages from the attachment hose. It takes only small items to completely block it off which will effect performance from both the beater bar/normal intake and also from use of the hose itself. The b***ards can be a pain to keep functional. I've personally removed rather sizeable wads of dog hair from mine that mucked up the works rather than went into the bag. Belts for the beater bar are notoriously short lived in these as well. When they break, the vacuum is only good as a floor sweeper. Stock up on both belts and bags for these. Good luck!
Oct 20, 2007 | Hoover Powermax U5242-930 Vacuum
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
108 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
