Question about Zanussi FJD1666W Front Load Washer
Zanussi Jet System IZ 161 S wont spin - Zanussi FJD1666W Front Load Washer
SOURCE: Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Posted on Jun 28, 2008
SOURCE: iz 161 w jet system washing machine
I have had a similar problem before, check that the hose outlet is not blocked, or that the drainage pipes are not blocked.
Posted on Jul 10, 2008
SOURCE: My Zanussi IZ 161 washing machine has a dreadful
hi ,well its the wee door down at the bottom right ,open that and loads of water will spill out,it will stink,mop up water and clean out drainage,that should do it,its a simple job and it willl save u pounds,it is just a build up of smeelly water
Posted on Jul 23, 2010
  • 7 Answers
SOURCE: Hi I Have a IZ 161
The speed of spinning in the washer depends on the weight of the linen in the machine. if the machine is not fully loaded it will create an inbalance and the motor control unit will sense this and hence spin at a low speed. Solution is to ensure that the machine is fully loaded with enough linen.
Posted on Oct 05, 2010
  • 1527 Answers
SOURCE: Hi I have a zanussi
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
Posted on May 27, 2011
Is the alan screw that holds the pully for drum on zanussi iz 12 right hand or left hand tread?
Have a look at the beginning of the tread, and it will become obvious that it is left or right hand.
Jan 24, 2015 | Zanussi Washing Machines
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
Hi I Have a IZ 161 W goes through all cycles until spin starts in slow spin but thats it and the time does'nt move basically it is not spinning to full speed . appreciate any advice regards Sarah
Oct 05, 2010 | Zanussi IZ161W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
My Zanussi IZ 161 washing machine has a dreadful smell! I've tried completing a high temp wash and using soda crystals but it keeps on smelling and although it washes the clothes well, if you leave them in...
Jan 09, 2010 | Zanussi IZ161W Front Load Washer
Iz 161 w jet system washing machine
Jul 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi IZ 12
Regards. Paul C
Dec 31, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FJD1666W Front Load Washer Logo
101 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
