Question about Maytag Dishwashers
I have a Maytag quiet series 200 MDB8750AWS dishwasher. It fills with water and then "pretends" to wash. The spray arms don't turn and spray. I have taken apart the lower assembly and cleaned it
Also have checked and cleaned the inlet valve and tested the solenoid.
  • Tamara Hollis Jan 09, 2013
    I checked the impeller and it is fine. (my question was cut off above). If it is the pump motor, why does that not show up as an error code in the field test or manual te4st that I did (also cut off in my question?
danromarris
  • 101 Answers
SOURCE: Lower spray arm won't spin
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
  • 423 Answers
SOURCE: Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Posted on Apr 01, 2009
  • 297 Answers
SOURCE: Maytag quiet series 200 Legacy not cleaning
under the unit where the water line connects,this is where the filters are.disconnect the water line take the fitting off that the line was hooked to,screen is there under fitting.
Posted on Jul 15, 2009
StarGGundam2
  • 24 Answers
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
SOURCE: middle wash arm doesn't turn on quiet power 1 ge dishwasher
The last two holes (the ones wich give the spin to the arm) are blocked. Remove the arm and try to unblock with a thootpick and by running water into the arm.
Good luck
Posted on Aug 07, 2010
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here: https://www.maytag.com
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
Maytag mdbh945aww quiet series 200 dishwasher. can't get it to turn on. Any suggestions.
A circuit breaker may have tripped
The wash cycle control may be defective
The fill control valve may be defective
The door interlock may be defective
Sep 08, 2012 | Dishwashers
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Jun 29, 2011 | Maytag Dishwasher
Maytag quiet series 300 dishwasher leaves glasses on top rack with film on it. What can I do??
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
2) Adjust the detergent amount.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Aug 26, 2010 | Maytag 24 in. MDB9750AW Dishwasher
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
My Maytag quiet series 200 is a good dish holder but certainly does not wash dishes - tried different soap all settings only result - dirty dishes - ready to throw it out -
do you have a watersoftner if so may not be working properly if its ok then do you always have water sitting in bottom of tub area. try this fill sink with water on disposal side 1/2 the way open door to dishwasher remove the stopper turn on the disposal do you see water or movement in the tub of the dishwasher if so replumb so the drain does not come into the disposal and plug the disposal opening
Aug 19, 2009 | Dishwashers
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag Dishwasher Quiet Series 200
The 3 symbol on the face control panel light is on and starts flashing anytime you push any other button, and is full of water in the bottom of it. My wife says she stopped the washing cycle a couple of days ago but now it wont start back up.
This is a Maytag series 200
Mar 15, 2008 | Dishwashers
Dishwashers Logo
50 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
