Question about Fisher and Paykel Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
  • Fisher and P... Expert
  • 555 Answers
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
I have a Fisher and Paykel Smartdrive 9 washing ma - 2_11_2013_1_58_23_pm.jpg
Posted on Feb 11, 2013
4 Suggested Answers
  • 17 Answers
SOURCE: My Fisher and Paykel smartdrive
Sounds like you have described this fault.
43.(00101011) Phase 1 to 6 - OOB Switch Fault The Motor Control Module has found that the signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Primary Source: Mechanical.
Action: 1.Check that the out of balance switch is free to move.
2.Check that no harnesses are blocking switch movement.
3.Check that the switch operates correctly when activated. Replace the switch if suspect. 4.If the out of balance micro switch shows signs of corrosion, replace the switch and switch harness, and fit a condensation kit to the console area if not incorporated in the top deck.
5.Check that the SmartDrive is level and also that the bias spring is in place.
Secondary Source: Wiring.
Action: Check the harness to the out of balance switch is connected correctly. The terminals should be connected to the normally closed position. If the harness terminals show signs of corrosion, then fit a new harness and switch.
The switch is located under the main computer. To get it out first unplug machine from the wall, then you will see two screws on the top back of display console take them out and remove console. Now you should see the main computer dissconect and remove, once out you can now get at the out of balance switch. Carefully remove it by pushing the tabs back one at a time again be very careful here as the tabs can break very easily. Once off unplug it from the wiring loom and then source yourself a new one.
Posted on Sep 30, 2011
  • 100 Answers
SOURCE: Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Posted on Oct 30, 2007
  • 1531 Answers
SOURCE: fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Posted on Mar 08, 2010
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have a F&P smartdrive 9 and you turn it on and it won't start filling up
Hi just read your posting.I need the model number of your machine, which is located on a sticker at the back of your machine at the top.Please reply with this information and I can help you rectify this fault.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel smartdrive 508 filling slowly
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
398 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
