Question about Grundig GU26DVD 26 in. LCD TV/DVD Combo
Dvd stuck in the player how do i get it out
Dvd trying to eject inside it when it trys to eject all the time and a red light flashing inside
Recently the CD player stopped working with a cd inside it says error 1/error 2 after it trys to load it also won't eject the cd at the same time this started the usb also stopped charging my devices
Try to put another cd in on top of the stuck one . don't force it , just push in a little ways then pull it out . Sometimes that will make player eject the stuck one. I would take it back to whoever installed the radio.
Dec 05, 2015 | Cars & Trucks
Why can't we get the dvd to eject?
Possibility 1 -
The laser light inside the DVD player is most probably no longer aligned and cannot read the beginning of the disk. Therefore it keep on trying to find the first line but it can't.
Possibilty 2 -
Your husband entered a pirated copy and sometimes the first few tracks are unreadable due to the lower quality of DVD-R used and it jams the laser light inside the DVD player.
What needs to be done is to unplug the DVD from its source and gently pull open the DVD drawer in order to remove the stuck disc inside. Once that is done, power up the unit and press on the "eject" bottom so that the drawer can close itself.
Good luck.
Aug 16, 2012 | Samsung DVD-V4600 DVD Player/VCR
The pc froze whill i was uploading music onto my creative zen v plus and now the screen on the handset says docked and has the docked picture on it with flashing red lights either side. the handset is not...
Try holding the power button down for an extended period of time. If this does not work, there should be a small hole on the side of the device that will reset the player. You'll need to use a paper clip to press the button inside the hole, similar to ejecting a cd/dvd that is stuck in a computer. Hold the button down for several seconds to reset the device.
Feb 28, 2011 | Creative Labs ZEN V Plus MP3 Player
The dvd player is frozen, and a dvd is stuck inside . how can I get my dvd back?
I have one that is the same way, but looks like the circuits never reset, all lights stay on. plus will not open
Nov 15, 2010 | Aiwa XD-DV370 DVD Player
We've got a DVD stuck in our DVD player in our Nissan Quest. The eject button won't work and the player is showing "No disk" on the display. The player is situated under the passenger seat facing the...
Page 4-62 of the Owners Manual for my 2006 Quest has this procedure for a stuck DVD:
1. Record the radio presets
2. Disconnect the negative terminal from the battery for five minutes
3. Reconnect the negative battery terminal
4. Check to see if the jammed DVD has been ejected. If it has not, try to eject the DVD by pushing the eject button.
5. If the disc cannot be ejected see your Nissan dealer for further assistance
6. Re-program the radio presets
I have used this procedure on two occasions, and it works.
The Owners Manual also says that playing DVD-R and -RW disk might cause the player to player to malfunction.
Good Luck!
Sep 22, 2009 | Car Audio & Video
DVD stuck inside
This DVD does not have a small hole at the front!!!
Dec 26, 2007 | Protron TPL-C01
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD light stays constant dim red (orange).
One usefull thing to try is the reset button that should be on the back of the player(that's where it is on another player I know of). It's likely that your problem started already with the stuck DVD, and that the manual eject wasn't the cause of it. Don't miss on the warranty if still valid. I also found something interesting, this is probably a known problem, and cyberhome is somewhat shirking responsibility... following the directions on the cyberhome support pages site on how to manualy eject a disc, it says "If the unit is an orange or flashing light then you may need to send it in for service. If the unit was purchased after 3 months but within 1 year you will have to pay a fee of $14.95 with proof of purchase. If the unit is past 1 year or no proof of purchase then you will have to pay $34.95. If you are still under the return policy with the retailer you purchased the unit from try returning it for an exchange." which to me means that they expect this to happen often, and that it's a 100% design flaw. So go make some noise, and tell them you know what's going on, and you'll start a website trashing them if they don't fix it free of charge etc etc ;] Good luck, let us know how it turned out, comment back!
May 03, 2006 | Cyberhome CH-DVD 300 DVD Player
Grundig GU26DVD 26 in. LCD TV/DVD Combo Logo
21 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
