Question about Micro Electronics PowerSpec 8420 PC Desktop
What is that AST red button on my Power Spec 8420 desktop power supply
Every time it is pushed it lite up a different LED color .what are these different setting?
    Sergeant:
  • 247 Answers
It sounds like an Automatic Self Test. You would need to consult the power supply manufacturer's handbook. For example see a video from Dell here: http://www.dell.com/support/troubleshooting/us/en/04/servicetag/3MJ0HV1
Posted on Jan 09, 2013
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....
Two reasons I could think of
Low toner.
Pre-set counter on cartridge reaches limit.
Try removing the toner cartridge and powering the unit on.
While unit is plugged in, re-install cartridge.
Not knowing how old the printer is a the amount of use, it is had to answer
Apr 30, 2014 | Samsung ML 2010 Laser Printer
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Wont power on.
to/ Japiering
all you have to do is re-charger them with the plug.
p.s.the re-charger comes with a set.
from hannah .l
Aug 02, 2008 | Nintendo DS Lite Console
TV WILL NOT TURN ON
The power supply, and or one of the circuit board is defective. The set will require shop service.
Jerry G.
Jul 26, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Satellite 2430 wont boot. when the start button is pushed nothing happens
Dear Customer,
1.if no sound
2.no led indicator lights up
than definatly its a power supply problem check your SMPS at top back side of your cabinet .
disconnected SMPS than ckeck its power supply at different ports.
THNX
May 17, 2008 | Toshiba Computers & Internet
Dell optiplex gx260
Reference the Power LED States
Dell OptiPlex and Dimension computers and Dell Precision workstations have incorporated the use of the multi-state power button LED as a hardware status indicator. The power button LED illuminates in two different colors and can also blink, which allows for indication of five different system operation states. (Table 1)
LED State
System State
Steady Yellow The power supply is functioning, but the system is not processing data. This may indicate an issue with the system board or CPU. Blinking Yellow The power supply is receiving power from the source but is unable to properly distribute it to the components. This may indicate a power supply problem. Steady Green This generally indicates that the system is functioning normally. However, if problems are detected with installed components, the system may initiate a beep code. Blinking Green The system is in a Standby ACPI state. Off The system power is off.
Feb 24, 2008 | Dell OptiPlex GX260 PC Desktop
Problem with my dell dimension 4600
Does the hdd lite come on? cd lite come on? The blinking lite on the power is an indication the bios or power supply is having trouble. strip the unit of all devices except hd, kb and use the vga built in video. Remove the ram also. restart and see what happens.
Dec 08, 2007 | Dell Dimension 4600 PC Desktop
Micro Electronics PowerSpec 8420 PC Desktop Logo
49 people viewed this question
Top Micro Electronics Computers & Internet Experts
Dennis Maeder
rclarke250
Level 1 Expert
RSole
Are you a Micro Electronics Computer and Internet Expert? Answer questions, earn points and help others
