Question about Bissell 6594 PowerForce Bagless Upright Vacuum
How to change the fuse or breaker on my vacuum
Where is the fuse
  • Official Brand Answer
  • 315 Answers
You may want to contact a BISSELL Authorized Service Center to have a qualified technician inspect your vacuum.
Here's a quick link to locating one.
http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Jan 09, 2013
Stopped working during use. Cooled down, been two days, still no power at all. Could it be a fuse? If so, how do you change it? Thanks!
Might be a fuse but probably not. Could be an internal thermal breaker or thermal fuse but internal breaks in the power cord are common faults with portable appliances.
If you are competent and can work safely it needs systematically checking through with a multimeter.
Apr 24, 2016 | Dyson Stowaway DC23 Bagless Canister...
Dead Dirt Devil Featherlite
1. Power cord not firmly plugged into
outlet.
1. Plug unit in firmly.
2. Blown fuse or tripped breaker. 2. Check fuse or breaker in home. Replace fuse/
reset breaker.
3. Needs service. 3. Take to service center or call 1-800-321-1134.
4. Thermal Protector activated.
4. Unplug cleaner. Allow to cool for 30 minutes
Nov 03, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Dirt devil bagless upright not turning on
fuse/reset breaker
Sep 20, 2012 | Dirt Devil 'Dynamo' UD40280 Bagless...
Vacuum quit in mid job will not start again
Don't know if your vacuum has a fuse in the power feed circuit. Most modern appliances do. If so, the fuse is shot. If not it's iether got a bad internal connection or the motor is fried. Also you mentioned a "reset". this sounds like a circuit breaker. Sometimes these breakers go bad and are replaceable.
Jul 02, 2012 | Riccar 8925
Euro-pro #S3101 doesn't turn on
Check in the following order.1. Plug unit in firmly in wall socket.2. Check fuse or breaker. Replace fuse/reset breaker.3. Check the continuity of the power cord.
Oct 30, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Suddenly stopped running in the middle of vacuuming a room. Tried another outlet and still no power.
You have to go to the electrical panel that serves your home or apartment and locate the fuse that is blown [ if there are fuses, replace the blown one with a new one of the same amperage] or the circuit breaker which has kicked part way off. With a circuit breaker you have to turn it all the way off and then back on in order to reset it.
Aug 14, 2009 | Panasonic MC-V5481 Upright Vacuum
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Rick
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
200 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
