Question about Watches
Can not pull out the stem from sitizen-1102,a watch
  • Watches Master
  • 18,394 Answers
It should pull out quite easely can't think what can be stopping it unless it needs oiling or serviceing at jewelers.Here is manual > http://c5602631920d46a2508a-8d72983753baa190ad1811b919e590cc.r52.cf1.rackcdn.com/calibers/1102_ebook.pdf
Posted on Jan 10, 2013
Testimonial: "thanks for the help, the back of the watch was a tight one and it took quite a bit of fidlling to get the thing off, thank you agaqin leon."
  • 1 more comment
  • leon feneridis Jan 12, 2013
    thanks for the help all fixt now,thanks, leon..
  • Les Dickinson
    Les Dickinson Jan 12, 2013
    good glad to help anytime
  • leon feneridis Jan 13, 2013
    thanks again mate leon
2 Suggested Answers
idkia_33
  • 70 Answers
SOURCE: Stem pulled out of the watch when trying to set the time
radioshack, walmart, or a jewelry store
Posted on Jan 22, 2008
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Mar 25, 2014 | Casio Forester FT500WV-3BV Wrist Watch
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
I pulled the entire crown and stem out of my Rolex President. What is involved in fixing it?
The repair for this problem may be quick and inexpensive--or somewhat more expensive. Either way, it's considered a minor repair.
The crown and stem assembly in held in a Rolex movement by a small pressure screw. When this screw is loosened, the stem can be cleanly pulled out of the movement without damaging any parts. The movement can then be removed from its case. If the screw is too loose, it is sometimes possible to pull the crown and stem out with ordinary effort. The simple fix for this would be to have a watchmaker take the back off your Rolex (requires a special wrench) and slide the stem back into the watch while loosening and re-tightening the screw. If that's it, the repair takes about 5 minutes, most of which is spent removing and replacing the watch back.
Things can get more complicated. The set stem interacts with a thin sheet metal spring / detent that helps the stem "snap" to its various set and wind positions. Sometimes, when a stem gets pulled out, the force of that can snap the delicate little finger in this watch part. Replacing this watch part will require that the movement be removed from the case and the hands and dial be removed for access to the part. Once you get to it, the part itself can easily be replaced--it's designed to be replaced without disassembling the whole watch movement--but there's considerably more effort involved than just sliding the stem back in and tightening down the screw.
May 08, 2011 | Watches
How to set day on non digital george watch
I'm not familiar with the George watch but analog (non-digital) watches typically have a stem with which you set the time and the day. On most watches the stem has two clicks when you pull it out (gently). The first clich should set the day by rotating the stem counter-clockwise while the second click sets the time. On wind-up watches this stem also winds the watch when not pulled out.
May 01, 2011 | Watches
I just bought a Bulova Super Seville watch how do you set the day and date?
Pull the stem out one click, rotate stem clockwise to set day, counter clockwise to set day, pull stem out to second click to set time
Feb 22, 2011 | Bulova Men's Watch
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
I have a problem pulling out the stem to set the date on my Roadster. Can you help? I can't seem to grasp the stem securely enough to pull it out. Thank you
mcdevito 75 here, you should be able to get a finger nail just under the stem to lift the stem to set the time, day/date, first be sure the stem isn"t a screwdown type, gasp the stem and turn it to see, if it is a screwdown type, simply un-screw the stem then pull it out to set the time, day/date. If all fails your local or any jeweler can help.
Jun 16, 2010 | Cartier Roadster W62016V3 Wrist Watch
How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Jul 09, 2009 | Bulova Watch
Set date on skagen 496sgsc
I used to sell Skagen watches,don't know excatly which watch you have . I even went to their web site and couldn't find it. Most Skagens ( unless they are a chronograph with the three curcles on the dial) works like this: Your watch stem has 3 differant settings #1 all the way in #2 half way out , and #3 all the way out . To set the time you pull the stem all the way out and adjust the time. To set the date,pull the stem all the way out and turn untill the date changes ( this will make sure you have it on am-pm correctly) then put the hands at 6 o'clock. Put the stem all the way back in, then pull the stem half-way out. Start with the stem all the way in and slowly pull it out and you will feel the "click" when it is half-way out. MAKE SURE YOU HANDS ARE NOT BETWEEN 9 O'CLOCK AND 3 O'CLOCK, OR YOU WILL BREAK THE AUTOMATC DATE SETTING GEAR!!!!! Then either turn the stem clock-wise , or counter clock-wise , one of the two ways will set your date.
Oct 27, 2008 | Skagen Watches
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Watches Logo
41 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
