Question about ASUS Computers & Internet
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
Zenbook ux21a
  • jim pritchard Jan 10, 2013
    Hi Guys
    Hi Guys, thanks for your suggestions. I took an easy/cheap route to solving the problem. I bought a Netgear wireless USB adaptor for next to nothing and I now have excellent wifi reception I had already downloaded the latest ASUS wireless driver adaptor, so my logic tells me that the installed wireless adaptor must be faulty.
  • ASUS Master
  • 7,627 Answers
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Posted on Jan 08, 2013
  • 86 Answers
SOURCE: cannot connect to wifi from
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Posted on Dec 10, 2008
  • 86 Answers
SOURCE: cannot connect to wifi on our bt home hub
Now:
type cmd and enter
  • 341 Answers
SOURCE: Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Posted on Mar 19, 2010
Testimonial: "Many thanks I'll give it a try.I guess the only limitation is that I have to have my PC online to be able to allow the wifi laptop to print."
  • 23 Answers
SOURCE: my aspire laptop is not
try to update all ur drivers for acer . i hope it will work then
www.acer.com
Posted on Aug 11, 2010
SOURCE: my samsung r519 has stopped connecting to the internet
Does the Laptop say it is connected to your wireless router? If not, connect to your router. Maybe the laptop is continuously polling because you keyed the Wireless Network Key/Password in wrong. If it's wrong, it will never connect.
Try disabling the wireless connection, then enable it and see if it connects and lets you out to the internet.
Make sure you are using the same Authentication (None, WEP, WPA, WPA2) as the laptops that you say work.
Posted on Apr 09, 2012
A VERY poor wifi reception
How old is the router? It is common for them to lose range as they age. More than 3 years replace it.
Oct 15, 2014 | Tablets & eReaders
Ipad 4 very slow wifi takes forever to download any sites I think because in my bedroom bad area
move closer to the wifi hub.
if the hub is over loaded (is it yours, or at starbucks?)
state exactly where you are, so we can answer.
and if at home ,state wifi point, brand and model.
and what internet you have , slow DSL, fast, cable or FIOS.
Oct 01, 2013 | Apple Ipad Tablet ( 3G , wifi , WiFi + 3G...
Sony vaio loses wifi handshake
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 24, 2013 | Sony Computers & Internet
Ipod touch losing wifi connection
If you are moving from place to place in the house, there may be dead spots? Are the other devices static? Is it the only device that moves about the house, all the time? Perhaps it's the Apple device, the antenna? Try at another location. Contact Apple, it may be a Known fault, You have heard of the antenna issues with the iPhone 5? If you hold it a certain way, it doesn't connect or will lose a signal.
Dec 26, 2012 | NetGear RangeMax Next Wireless ADSL2+...
Cannot connect to any wifi outdoors
Its because you are "out of range" you need to get a device that broadcast a stronger signal or reposition it so it provides signal to where you are.
Oct 09, 2012 | Coby Tablets & eReaders
My acer aspire loses its signal randomly then comes back. Other laptops in the house are fine for connection. Any advice in simple terms appreciated as I don't know how to remove acer software for
Have had similar problems with two Gateways that are actually Acer--both two feet away on either side of each other: one or the other will lose connection--so not the units---if move the one not connecting closer (it is 50 feet with 3 walls between it and router) it will then pick up the wireless and work fine--I answer about 300 questions here each week so end up to avoid this in the mud/laundry room where I can depend on the signal and also have a smoke if I want.
May want to as a test move it closer to the router and see if same issue or not.
Apr 20, 2012 | Acer Aspire One AOA110-1588 Notebook
Does not connect to to wifi connection when wep
My neo v kept losing the WiFi connection after a while, only connecting when I turned off and on the router despite always seeing a high signal.
I changed the router from wep to wpa2, same issue. Then I changed the DNS server in the router from the telefonica default to Google's own, I.e. 8.8.8.8 and 8.8.4.4. Now my phone's WiFi connection is rock solid.
Dec 29, 2009 | Sony Ericsson Satio Cell Phone
We have an industrial setting. We're using RF devices, scanners on lift trucks that move through our warehouse. We are losing connection when the device gets out of range of one access point and tries to...
Plz check for 3 things:
1. All of your AP should given access to roaming devices, for this all of your AP are should connected with each other.
2. WiFi chennal for your device should be same for all AP.
3. Configure 802.11b or 11Mbps speed on devices.
Plz revert in case
Thanks for contacting Fixya
Mar 23, 2009 | 3Com Wireless LAN Managed Access Point...
Wifi is not working
try to update rom image or radio image to newest version if nothing is change down to your device rom image file
May 04, 2008 | T-Mobile MDA
Computers & Internet Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
