Question about Estate TEDS740JQ Electric Dryer
ELECTRIC DRYER TEDS840JQ0
Dryer runs then entire dryer shuts off within 2-3 min. It spins. The heater is on for only short period of time. The fan on the bottom back makes a crunching sound just b4 the dryer shuts off.
  • lucky05mom Jan 20, 2009
    I know it is broke. Thats why I am here. I have been reading other articles. Could it be the thermal shutoff switch? If the dryer is run on air only it stays running. The dryer is around 4 years old. I can NOT return it. I wish I could!!!
    I just replaced the washer. It was around 15 years old. I did many repairs to keep it going. Due to its age & constant repairs it was replaced. The dryer is not that old. I can NOT just return it.
    Problem Solver:
  • 4 Answers
Its broke retern it
Posted on Jan 20, 2009
  • dominic nixon Feb 06, 2009
    it could be the switch but it sounds like the fan is hiting something and it over heating
What does blinking pf mean
This means 'Power 'Failure'.
This could be from the circuit breaker being tripped and then was reset, wall outlet issue, or possibly if the cord was replaced then the screws conecting the wires to dryer may not be tight. Make sure dryer in unplugged before checking connections.
Some homes have an energy management system where higher energy use appliances are given a priorty so they all cannot run at same time so keeps your electric bill lower.
For example, the water heater and a/c system would be wired to override the dryer so if both these were runnng and then you turned on the dryer, the control unit would shut power down to dryer within a short time.
Hope this helps.
Jun 27, 2014 | Kenmore Elite HE4 Electric Dryer
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
I start time dry for 60 mins. It will run for
The heater element is not heating, they are fragile easy to get to at the back of the dryer. Check the thermal or overheat switch too, but would bet its the heater element.
Nov 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Fisher&Paykel electric dryer: starts then stops
it sounds like the thermal fuse is bad. if you take the front cover off you will see a fuse with a red button. that might be what is causing it
Aug 02, 2008 | Fisher and Paykel DEGX1 Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
136 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
