Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Our F&P dishwasher draw is starting to turn off at 56 minutes each time we use it. We have to push the start/pause button to resume wash cycle. What is causing this to happen. We have no leaks at this time and are not experiencing any faults coming up.
  • Fisher and P... Master
  • 3,247 Answers
Feel water temperature when dishwasher stops. it is likely the heater is faulty. Does this happen in the cold water wash cycles?
Posted on Jan 21, 2013
  • 883 Answers
SOURCE: Dishwasher not working
disconnet power to unit....circuit breaker...wait 30 minutes....try again
Posted on Jun 02, 2007
  • 62 Answers
SOURCE: dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Posted on Feb 13, 2008
stephanos18
  • 144 Answers
SOURCE: Fisher & Paykel Dishwasher DS603- water not draining out
Does it show a fault code? eg F4?
Posted on Mar 27, 2009
  • 3247 Answers
SOURCE: F & P DD603 starts to wash then beeps &
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Posted on Dec 15, 2009
  • 69 Answers
SOURCE: leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Posted on Mar 18, 2010
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
Aug 29, 2015 | Fisher and Paykel Washing Machines
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Nov 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Pause lock keep showing up on screen
Hi Lance - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Sep 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a gsd5610 and my drying button is blinking.the unit will not start
Someone opened your DW during last washing cycle. The Machine paused but no-one pushed the button to resume the cycle. It's still waiting for you to tell it to finish last cycle. Press your PAUSE/Cancel button 'til the light goes off. Then use your machine as you normally would.
Hope this info was helpful to you. Good Luck! :-)
Jan 31, 2010 | GE 24 in. GSD5930 Built-in Dishwasher
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
37 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
