I have a 2000 Chevy Tahoe that did the same thing. I changed the oil pump, new oil, and head gasket. It now has power and doesn't fall on its face when I step into the throttle hard. Hope this helps.
I would check the timing could have jumped a tooth on the timing belt/chain. Also check the rotor in the distributer make sure that it is not worn out. I have also seen a plugged catletic converter cause big time power loss and really strange problems
If it shakes all the time whether mashing the gas or letting off of the gas then it may be a tire, but if it just shakes when mashing the gas then I would look at the driveshaft.
it might be the ECU, when cold the computer raises the iddle to warm it up, when reaches temp., it dropes it down to normal iddle, but it might not know where the correct iddle is, it might be another sensor like a cam, map, throttle position senssor.
put an mustang 5.0 if you want real fast put cool air intake and headers with 2.5 inch exhust and 20 series flow master and dual all the way out the back cost a little bit but well worth it if you wanna smash on little imports ,mustang,camaro you mostlikly have the 8.8 rearend witch is a good rearend and you can gear it to your needs for quickness or speed however you want it for your motor .
