Question about Emerson EWF2004 20" TV
Auto channel programming not working - Emerson EWF2004 20" TV
    Top Expert:
  • Emerson Master
  • 75,581 Answers
Check and replace the main system memory IC. This is a very small IC, can be located very near to main system control IC.
Posted on Jan 09, 2013
TV will not switch channels. Manually nor remotely. Hook up another TV everything works.
Most TVs have a manual or auto-program feature to add or remove channels. It is possible that you have de-programmed all or most of the channels.
Connect TV to cable or antenna, enter the main menu and look for auto program feature.
Apr 11, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Up channel and down channel doesn't work on TV or on remote.
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by channel programming has not been done yet. You must run cable TV directly into set and let the set do the auto programming. If you are using a " Cable Box " You can not auto program and must use the cable box remote.
Nov 19, 2010 | Vizio L32 32 in. LCD HDTV
Tv only gets lower channels
Go to settings manual, go to tuner mode, select CATV, than do an auto-programming or auto channel scan and you will be set.
Make sure it is not set to AIR
May 10, 2009 | Insignia NS-27 TV TV
Cant get channels to program manual or auto
Try the STANDAR mode search, instead of AUTO mode, also try IRC mode, and HDR more, maybe thats why you dont get any channel...
Mar 19, 2009 | Olevia 227-S11 27 in. LCD TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
I have an older Magnavox tv-vcr 13"combo, model MC132DMG01, I selected auto-programming to set the channels, now I can't get the channels I used to get, and I don't know how to override the automatic...
Auto-programming cannot select channels it can't detect. You may have to select manual programming and step through and set each channel manually.
Dec 30, 2017 | Televison & Video
The desgin of this unit is such that only the channel being recorded can be viewed. Try to manualy program channel 3 - p.25 in the user guide.. Good luck.
Jan 14, 2006 | Panasonic PV-M2048 20 in. Combo
Emerson EWF2004 20" TV Logo
52 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
