SOURCE: Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
SOURCE: Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
SOURCE: no suction power on my eureka boss vacuum (vacuum
Most probably a clog in the neck. This is where the power head connects to the body of the machine.
Remove the base plate (screws in). Take a look at the back of the head behind the beater bar. There is likely something blocked in the neck of the unit. Clear it out and you will likely me OK.
While it is open take the time to remove anything wrapped around the beater bar.
Good luck, please rate this answer if it helps.
