Question about Montel Williams LWHME HealthMaster Elite Blender
The pitcher is stuck to the base and I cant remove liquid is also spitting out of lid when in use
I can't remove the pitcher from base
    Sergeant:
  • 475 Answers
Try some grease on it, or very hot water.
Posted on Jan 11, 2013
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
Where do I find a replacement pitcher?
Link, Can you tell me what brand your blender is? This is usually found under the blender base or right on the front where the buttons are. Then we can tell you whether there are replacement parts or not.
May 08, 2015 | Blenders
My pitcher is stuck to the base and will not release. How do I get them apart?
You don't say what is making them stick together or what you've tried to do. Gentle heat is usually helpful and sometimes hot water can dissolve the "glue" that's causing the problem. If the pitcher is used for sweetened drinks or if it is a small pitcher used for milk or cream, the hot water can do the trick.
Mar 03, 2015 | K-Tec Champ HP3 Work Top Blender
Ninja lid removal
your pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
see page ten figure 6: http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100527.pdf
Nov 10, 2013 | As Seen On TV Ninja Professional Blender
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
Hi. We have a Cuisinart smart power blender. When we mix drinks, there is some sort of black residue seeping into the glass pitcher. Do you know what is causing that?
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Jul 14, 2011 | Cuisinart Blenders
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Dec 28, 2007 | Waring BB180 Work Top Blender
Montel Williams LWHME HealthMaster Elite Blender Logo
117 people viewed this question
Top Montel Williams Blenders Experts
eyecam
Ross Keen
Are you a Montel Williams Blender Expert? Answer questions, earn points and help others
