Question about Dell 5650 Computer Speakers
No sound, cenral and rear speakers Dell 5650 speakers
I Can't get any sound out of the Central Speaker (with the volume Knob) nor the rear speakers. All appears set up correcrly at the back of the computer and behind the woofer,
I've been onto the volume setting on the computer all is also in order (not muted etc) and I've also used and found the connector specified in the suggestions, all to no avail .
Both front speakers , howver, work Fine!
  • Anonymous Feb 15, 2009
    I have the same problem I have tried for weeks messing around tryin gto re-install drivers etc but nothin gworks - i recently re-formatted my hard drive but did not receive a cd for the sound card when i bought the pc from dell. I do have a cd but it is for a different card - please help too
The surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Posted on May 06, 2009
Dell Home Theater Speaker System MMS 5650, subwoofer not turning on...fuse NOT blown. Has turned on for a second and then goes back out. What is the problem??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
:((appropriate speakers)): also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 05, 2011 | Dell 5650 Computer Speakers
I have the Dell 5650 Computer Speakers..I had to reolad the audio driver.. now, the two fron speakers and the center speaker under the monitor work, but the two rear speakers are not producing sound..I...
If you are using Sound Blaster, go into "All Programs" and open the "Creative File" and then the "Audio Console", left click the "CMSS 3D" tab, under the "CMSS Modes" click on the selection box and select "CMSS". They should start working at once.
Sep 04, 2010 | Dell 5650 Computer Speakers
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
My Dell 5650 Woofer isn't working.
Please download the manual for Dell 5650 and check the placemat details if anything is missing.
And update me if that helped.
Feb 07, 2009 | Dell 5650 Computer Speakers
Dell MMS 5650 speaker Volume control
Since it has been working perfectly, you need you change the control knob, there may be a pershal contact that is preventing it from controlling the volume.
Jun 18, 2008 | Dell 5650 Computer Speakers
Not working at all
If all your connections are sound, call dell. If they can't do anything for you insist on a refund. (You have to get testy with Dell)
Dec 29, 2007 | Dell 5650 Computer Speakers
Dell 5650 Computer Speakers Logo
506 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
