Question about Whirlpool Refrigeration White Side Trim Perimeter Kit, Fits KSBS/FS25KWH, GD25FF/SF/BFCH, Replaces 8...
Replacing cubed or crushed ice switch on whirlpool refrigerator
I need to know if I can pop out the switch or do I have to buy the whole front assemby on part number 2180279.
  • 700 Answers
You shopuld be able to just replace the switch on the unit. gently pry the edges of the outer cover off and then you have full access to the inner workings and parts. good luck
Posted on Jan 21, 2009
My lg refrigerator will only do crushed ice not cubes
crushed ice is better for your Margareta anyway... but chances are the switch or button that allows you to select crushed or cubed is broken...
Sep 27, 2014 | LG Refrigerators
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
Sep 05, 2017 | Refrigerators
My ice despenser has a switch for cubed and crushed ice. I have the switch on cubed and only crushed ice comes out
usually there is a device in the ice bucket that activates or deactivates for cubed or crushed..that is controled by another (stirup) behind the bucket, that may be frozen up, thaw the whole refer...then see what happens. It might be in the switch...as well, if so call some one
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cubes will not dispense, but crushed ice will. GE Profile TPX24PRYA
If the auger motor turns in either setting we know that the auger motor is OK, and if it does not turn in both crushed and cubes that leaves a problem with the WR55X129 time delay, which is the part that you switch to go from cubes to crushed to water.
Dec 06, 2008 | Refrigerators
Ice dispenser not dispensing.
the hex wrench your after is know as nut ddriver screw drivers / you can remove the auger assembly quite easily the activation switch is located in the door assemby. be carefull the auger is powerfull.
Aug 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice dispenser in door- won't deliver whole ice
Dear Sir,
I have purchased a whirlpool refrigerator on dt.05.11.2006 from M/S.Ganesh Enterprises, Angul bearing Invoice No. 335. last few days the main door of the refrigerator is not working properly. A part is broken from the door(clamp). Inspite of repeated contact and reminder the dealer have not taken any action till today and telling that the parts is not available.
I am very much dissatisfied with the service of the dealer. Therefore I am request you Sir, kindly look into the matter and necessary action in this regard please be taken.
Thanking You,
Yours faithfully,
R.Agarwalla,
06764-232367, 234667
Jul 15, 2008 | Refrigerators
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Always crushes ice
This was easy to solve after reading some posts which mention "a plastic flap" which is opened or partially closed by the metal rod running under the ice cube tray.
There is indeed a flap which is inside the front of the removable ice holder/dispenser. The flap should be able to open fully so ice can fall out. In mine it could only move 1/2 inch because the flap was laying on the wrong side of a small peg which guides it.
I was unable to free the flap to open completely by pressing on it, so I had to unscrewed six screws to take off the front plastic facing and the on the front plastic housing. Pushing on the metal rod immediately put the flap back into it's correct position. I then replaced the plastic front.
I can now have either whole cubes or crushed. Boy was that easy to fix!
A repairman recommended replacing the electronics ! !
I assume this misalignment might be caused by too much pressure when the ice cubes freeze solid or something? If it happens again, I know it's easy to fix.
Nov 06, 2006 | Kenmore 55692 / 55694 Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
