Question about Panasonic Televison & Video
TC-P50C2 10 BLINKS
TURN ON SET NO PICTUTE OR SOUND FRONT LED BLINKS 10 TIMES
    Producer:
    Uploaded 30 video answers.
  • Panasonic Expert
  • 155 Answers
Try this for symptoms and cures
Posted on Jan 19, 2013
premtech
  • 934 Answers
SOURCE: Phillips Plasma Error
That unit is a BP2.2UAA chassis and from the sympotoms you're describing you have a power supply problem. The power supply is an smps (switch mode power supply) Philips p/n# 996500033880 and available at Vance Baldwin for $473.58 plus shipping, which includes a $250.00 core which you can get back when you ship them the old part.
If you buy the supply yourself and attempt the repair it's a simple plug-n-play but you should also check the Y & Z sustain boards for possible shorting.
Bill
Posted on May 20, 2008
  • 138 Answers
SOURCE: Philips 42PF7320A/37 won't power up Led blinks 7 times
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a boar connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue ect screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Posted on Aug 20, 2008
SOURCE: Memorex HDTV no picture
I am going to assume that you have not already found the answer to this problem. It is actually pretty common for flat panel televisions in the winter to be too cold to turn on. What I did when faced with this problem on my 32 inch memorex was turn it on for 30 minutes while covered with a fleece blanket, than turn it off. When you turn it back on it should work...did for me!
Posted on Jan 08, 2009
  • 90 Answers
SOURCE: 42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Posted on Feb 24, 2009
pilot210
  • 39 Answers
SOURCE: Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
Posted on May 19, 2009
Panasonic tc p50g15 tv will not turn on tried 1 minute unplug reset and 20 sec power button hold in. Did not work now no led lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 17, 2016 | Panasonic Televison & Video
14 blinks Panasonic TC-P50A30 TV
Aug 01, 2016 | Panasonic Televison & Video
Panasonic TC-42px14, 12 blinking LED
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Mar 15, 2016 | Panasonic VIERA X1 series TC-42PX14 42...
No picture no sound just blinking red light blinks 8 times I tried unpluging for 5 min but no go
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 27, 2015 | Panasonic VIERA TC-P55ST50 55 in. 3D...
What board do I need to replace to fix my plasma TV that does not turn on?
May 06, 2015 | Panasonic Viera TC-P65ST60 65" 3D...
Panasonic TC P5G20 turns on but screen will not activate. It then clicks and the led blinks 13 times. I've turned it off and on a few times and once the light blinked 4 times, but it's now...
Dec 16, 2014 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Panasonic tc-p50ut50 light flashes 9times wont turn on
Aug 15, 2014 | Panasonic tc-p50ut50 plasma panel
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
Jan 22, 2013 | Panasonic Tc-P50x1 50inch Class Viera X1...
Televison & Video Logo
241 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
