Question about Tunturi T40 Folding Treadmill
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
    Top Expert:
  • Tunturi Master
  • 12,223 Answers
Please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
I have a tunturi t40 treadmill an error code e7 ap - 1_8_2013_11_10_13_pm.jpg1_8_2013_11_10_32_pm.gif
Posted on Jan 08, 2013
2 Suggested Answers
SOURCE: The riser on my Tunturi T20 is stuck on maximum
Phil, I have had the same problem today.
did you solved the problem already?
Posted on Jan 30, 2010
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
Pro runner 1600 treadmill
this is a error with two alternatives; God bless you
2)Alternative:
Oct 24, 2013 | Tunturi Exercise & Fitness
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
2)Alternative:
Jul 15, 2013 | Exercise & Fitness
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
What is error e7?
This error means 2 alternatives : a) elevation motor NOT working + b) display not working too.
However you are mention that after 3 seconds the machine goes stop.This reveal that you must to do the following:
1) LUBE the deck belt very well, lack of maintenance shut down the machine for protection.
2) LUBE the rollers bearing,too
3) test the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are not the board is faulty.
see the block diagram
1) alternative for error codeLa) elevation motor LUBE the gear and shafft and adjus the pot.,tight any wires connector and clean
2) alternative for error code 7 b) adjust the REED switch, clean and tight the wires connector very well. see the block diagram
after you fix RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
7_17_2012_10_13_08_am.jpg7_17_2012_10_13_31_am.jpg7_17_2012_10_14_05_am.gif7_17_2012_10_14_22_am.gif
Jul 17, 2012 | Tunturi T30 Treadmill
E7. Elevation stuck and wont come down
Sounds like there is either a malfunctioning button on the upper console, or a shorted triac driving the elevation motor(or other elevation control device) Can you see any part numbers on the motor control board? Make sure the tread is unplugged before looking around.
Oct 24, 2010 | Tunturi T20 Folding Treadmill
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
E7 fault
My Tunturi T20 treadmill male end Unscrewed from female end. What's the solution?
Apr 20, 2010 | Tunturi T20 Folding Programmable Treadmill
Tunturi T40 Folding Treadmill Logo
530 people viewed this question
Top Tunturi Exercise & Fitness Experts
Shehu Pro
Shehu Pro
gbob59
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
