F18 error code on siemens washing machine
Hi, I have a Siemens E12.46 washing machine, E-Nr WM12E46SGB/01, FD 8809. I keep getting the F18 error code every time a wash cycle comes to its end, the drum still full of water. I have followed guidance in the instruction manual and online. I have drained it using the drainage hose and then by opening the pump cover. I cleaned out the gunk, there was a few bits of waste but nothing major. I have also checked the rear drainage hose and it is all clear into the drainage. The problem still persists, so I think it is the pump itself as I read that it should rotate freely when the pump cover is off. I can rotate it round with my fingers but there is some resistance, which I think the water would have a problem turning if not under enough pressure, which I think it is not draining. The pump seems to rotate 180 degrees by my fingers and then snap around the next 180 degrees into position again. This is true when rotating both clockwise or anti-clockwise. Does this sound correct? Also is this an easy fix, or do I need a manufacturer repair? I have paperwork from Domestic General for a 5 year guarantee that I took out when I bought it which states that it covers it for breakdown. Would this be covered? Many thanks for any help.
ginko
  • 19396 Answers
SOURCE: Problem with Hotpoint WD64 Washer Dryer
Effectively it looks like a water heating problem.
When the water cannot be heated sufficiently, the machine waits until water reaches desired temperature.
So that the program takes longer to complete.
Heating problems can be caused by:
Faulty heating element
Faulty heating element solenoid.
Faulty thermic switch (in this case the water will get hotter than normal)
The heating element and the solenoid can be tested for continuity using a multimeter.
If the machine is slow to fill check also that the inlet valve is fine and not obstructed.
Posted on Nov 01, 2008
SOURCE: bosch wfmc3200 will wash but will not spin or
I have the SAME problem as of TODAY!!!
What are you going to do?
Mine is filled with soaking clothes & water.
Posted on Feb 27, 2009
  • 57 Answers
SOURCE: During the drain water cycle it says Pump blocked.
the sump is located near the pump check that its not blocked
Posted on Jun 23, 2009
SOURCE: W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Posted on Jul 08, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
Error code in Siemens s14-79
Hi Lasin,
Search online for "error code *** Siemens s14-79".
Jul 17, 2015 | Siemens Washing Machines
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
Siemens washing machine error code e61
Some brands where technical information is not always available or hard to obtain are Bosch,Siemens,Indesit,Hotpoint,LG,Samsung..
Here you can Download Instruction manual For your washing Machine (Enter you Product code to Download Example: WXS1040/05 )
https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
Hope This help you out.
Sep 29, 2012 | Siemens Washing Machines
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
I have siemens washer serie IQ 1431. My door will not open and the washer is full of wash.How do i get the door to open?
Cause The childproof lock has been activated.
Resolution Deactivate the childproof lock. Directions can be found in your instruction manual.
The manual for your washer can be fount at at the following website. You will need the E-Nr number in order to get the correct manual. You can find the E-Nr Number on the rating plate of your home appliance.
Mar 08, 2011 | Siemens Washing Machines
Siemens washing machine - Error code F37 Thanks
Siemens washing machine - Error code.f16
Dec 07, 2010 | Siemens Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
