Question about LG 50PK550 50 in. TV
I have a line going through the screen - LG 50PK550 50 in. TV
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Fix a line going up and down ipad mini screen
This sounds like it is a heat related wiring issue with the screen and the connector to the screen. Best to take this in to an apple genius bar and show them the ipad when the line is present. They should be able to then replace the screen for you.
Oct 21, 2015 | Apple iPad Mini
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
My computer screen has lines going verticale through the screen and we bought a new screen but that was not it how do i get the lines to go away (color of lines is yellow with blue
Please check your video card if there is no problem with it. Try to use a different video card that is compatible with your pc and check if the lines still appear.
Sep 13, 2010 | Computers & Internet
Blank screen audio ok. Picture tube has a line only going up and down
adjust voltage G2 Screen. thats why have retrace line. resolder also CRT board.
May 31, 2009 | Proscan PS50700 50" Rear Projection...
Thick Black Line on Screen
This is caused by dead pixel sensors. There are hundreds of pixel sensors at the edges of the screen, when they go out it will cause a line varying in size depending on the amount of sensors that go out, and the line can vary in color, red, blue, green, white, and black. Unfortunately, the only fix for this is to replace the screen.
Jul 30, 2008 | Computers & Internet
Screen has lines
Most likely youve damage the lcd screen either by dropping it even though you didnt, but that would be the only cause this problem, line on a lcd screen are usually cause by a broken power current thru screen or a cracked lcd screen maybe it was defective in the first time. I dont know, but line are usually means no power or no information going thru screen.
need to be replaced.
Jun 27, 2008 | Kodak Easyshare M753 Digital Camera
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Blackberry not on Home screen
did you try and redownload software?
Sep 11, 2007 | RIM BlackBerry 7290
LG 50PK550 50 in. TV Logo
26 people viewed this question
Computer Repairing
Computer Repairing
