Question about Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch
My memovox is running too fast got it now for about a month
Anyone heard about such a problem ? all the best - C
I have a 1970 Memovox that has exactly this problem. We bought it for my Dad and my Mum gave it to me when he died a year later. The watch has spent more time being repaired than working. LeCoultre "fixed" it the first time and it promptly starting running fast again. Then several small watch makers all claimed to have fixed it -but every time the same problem. It has been claimed by these people that oil gets on the spring and shortens it hence the watch runs fast - I reckon about double speed. The solution? Buy a knock-off in asia - it'll run on time for years without the battery going dead, and cost one thousandth of the manufacturer's price.
Posted on Sep 13, 2007
    Sniper:
  • 51 Answers
Your question was cut off please explain your problem further Don
Posted on Jul 03, 2007
SOURCE:
I can't set the date on my watch - right now I have to scroll through the time setting mechanism hour by hour and day by day?
The date changes around midnight and you can usually advance the date by going past midnight until the date changes and then turning the watch backward to a time shortly before midnight and then winding it forward again.
How far back you need to go you will have to find by experiment but it should not be very far.
Jun 09, 2011 | Jaeger-lecoultre Master Compressor Memovox...
Mens Rolex Explorer. The no. 11 digit fell off , 16 months after purchase, and is now resting at the base of the watch face rendering this expensive timepeace useless.This Mens Rolex Explorer bought from a...
Its not unheard of depending on the age of the watch (you say you purchased it 16 months ago but it could be a 15 year old watch.) If it was a new Rolex watch you have a 5 year warranty, so it should cost you nothing. If it was a pre-owned Rolex you should have received a warranty from your jeweler, most of those are 2 years. If this is a watch with value, and one you will either hand down or at some point resell then sending an older watch to Rolex is the proper direction - save all the repair documents, with the original receipt and the box. A Rolex Explorer II in good condition in US is about $5k, so $380 for a repair, though high, is worth it. I would recommend that if you do send it to Rolex for this repair and it is an older watch have it serviced too. The watch is returned to you in perfect condition with fill documentation.
Lastly, you need not to send it to Rolex at all. Any good watchmaker/repair jeweler can do this for less than $380US.
Aug 14, 2017 | Rolex Watches
It was running too fast, so I had to frequently reset the time. Eventually the winding stem quit responding. I took it in to a jeweler who sent it out allegedly to a watch repairman. They've had it now...
Thanks for contacting FIxYa.
It would not be surprising to have to go overseas for parts and for it to take this long.
IF you can get back, I would try. Then I would send direct to Seiko as they should have the correct parts needed.
Go to following:
http://www.seikowatches.com/support/faq/repairs.html
Hopefully that is of some help to you. Best regards. Jewel
Sep 14, 2010 | Seiko Watch SNXJ89K1
The moving mechanism inside gets stuck and i have to violently sheck the watch to get it lose and start working
mcdevito75 here, Sounds like you need the watch serviced, specially if not so in 2 years. Check the repair service directory here at Fix Ya, bottom of the page click on repair service directory then watches.
Jun 25, 2010 | Jaeger-lecoultre Master Compressor Memovox...
Problems with setting the date on this watch
mcdevito75 here, It does seem to be a hard way to set the date. I would imagine to you have stem and not buttons, Try this slip your fingernail just under the stem (winder) and lift the stem to it"s first position, now turn the stem either toward or away from you to change the date easily.
Jun 21, 2010 | Jaeger-lecoultre Master Compressor Memovox...
TAG watch is running fast
You need to find a qualified watchmaker to correct this problem.
If the movement was replaced twice the same problem would not be happening again and again unless there is something you are doing that puts the watch in some kind of field to magnetize it or the place you took it to did not really do anything.
My guess is they did not do anything since you say they oiled the crystals. Just oiling a watch will not solve this problem. A qualified watchmaker would know this.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 11, 2010 | Watches
Ar4217 runs fast now stopped
I have never had a watch that ran as poorly as yours seem to be doing. You have a lemon orchard!
Perhaps if you contact the maker they might take pity on you and offer you a replacement. http://store.emporioarmaniwatches.com/ Scroll down to the bottom of the page to see the contact address.
Apr 08, 2010 | Giorgio Armani Emporio Armani watches...
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
15 to 20 minutes fast per day
if your caliber is automatic 7s26b something is wrong with the hair spring try a seiko service center anyway isnt something that you can fix by yourself!beware!far away from jewelers and local battery changers and other monkey magicians!automatic watch calibers are delicate and they ruine them!
Jan 21, 2009 | Seiko SKX173 Wrist Watch
Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Logo
577 people viewed this question
Top Jaeger-lecoultre Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
