No matter what way we put the paper in (feeder or on glass)
It turns it horizontal and centers it
we have a Canon Imagerunner 33006.
  • catering854 Jan 21, 2009
    YES!! IT WORKED !!! YAYYYYYYYYYYYYYYYY!!!
    Thank you SOOOOOOOOOOOOOOOO much~!
  • 168 Answers
Do you have the settings on the drawer right should be a round blue diail or slide, LTR is 8 1/2 side close to you LTRR is 11 inch side facing you
Posted on Jan 20, 2009
We have a Canon imageRUNNER 3230. Starting this morning, it has been printing everything off center. If you send a document to the copier for printing, it shifts the image to the left so that the far...
I would make sure that the paper guides in the paper tray are tight against the paper. And make sure the adf guides are close togather so the paper will not go in crocked Good Luck.
May 20, 2013 | Canon imageRUNNER 3230 Black and White...
Canon Color imageRUNNER C2550 legal size copying only works with single pages placed on the glass. Auto feeder ends up with image off center
when you making the copies, you MUST adjust the paper guides on adf/dadf. They are gray plastics left and right from original and can be moved to each other. They guide the paper rightly in adf/dadf.
If these doesn't helps, please describe what happens when dadf pulls the paper inside.
Apr 21, 2011 | Canon imageRUNNER C2550 Color Copier
Paper center black line
if your using feeder clean scanning glass on the left (small) copying glass.If line still remain should be drum faulty.
Feb 21, 2011 | Canon imageRUNNER 2200
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
The feeder in my office copier is not feeding the paper thru it. It only copies if you manually put it on the glass.
Hi, you need to open the adf cover, check for any leftovers of paper or clips, or... also clean the pick up and feed roller with alcohol by piece of fabric.
Also have on mind that the feeder is only for plain paper usage.
Sep 08, 2010 | Canon imageRUNNER 1023iF Black and White...
Black horizontal line on copy
Check the **** glass that the paper passes over when you use the document feeder. There could be something on it.
Sep 02, 2010 | Canon imageRUNNER 3225 Black and White...
Document Feeder Jams
This could be a simple problem of the fees rollers just being dirty or an obstruction in the path of the paper.. sometimes paper clip or staple gets pulled through you can test by putting a heavy paper or piece of card in dock feeder and see if this goes through if you lift up the cover try to see how far the paper goes in yu might catch the obstruction you can also clean the rollers with a little glass cleaner and a soft cloth.. goood luck A
Jun 09, 2009 | Canon imageRUNNER 400S Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Plain paper is coming out with black lines on it
if the lines on the copies happen only when you use the doc feeder then you have something on the small slot glass if you put the document on the glass and make a copy if there is still a line it is probably the drum
Dec 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imagerunner 3300 line on page
if you are using the feeder then there is something on the thin glass and it needs to be cleaned. if you are using the platen glass and the line is still there then you need a new drum.
Oct 29, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
k24674
