Question about Krups Caffe Centro 888 Coffee Maker, Espresso Machine
My krups 888 coffee/expresso machine does not function on either coffee or expresso and the hot plate does not work. This happenned all of a sudden from one minute to the next. What could be the probl
Could it be a fuse, and if so what is the amperage
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Posted on Aug 21, 2008
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
  • 279 Answers
SOURCE: We have a krups combo expresso and coffee maker. I
When is the last time you cleaned it out w/ vinigar?
Posted on Sep 18, 2009
SOURCE: my Krups 4000 Expresso machine while still heating
I had the same problem. The issue was that the machine needed a clean to dissolve Calcium build up from the water. I used a commercial cleaner available at my local supermarket but have since used white vinegar and get just as good results. I just put about a cup of white vinegard in the water haopper and run the machine without the group attatched. I run the steamer wand and then put another cup through with the group attatched . I then rinse a few times with fresh bottled or distilled water.
Posted on Nov 27, 2009
  • 22 Answers
SOURCE: Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Jan 31, 2010
No power on the coffee maker/clock. Expresso side
Look for a defective heater, thermostat, safety thermal fuse, or a possible interconnecting wire is broken. This not considered a homeowner repair as it involves mains power and if the safety fuse blew, something made it fail. Because this is likely to be fairly expensive to repair (at a service shop), you should get an estimate and compare that to a new machine. Hope this helps!
Apr 12, 2010 | Krups Caffe Bistro 867 Espresso & Coffee...
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
The coffee maker doesn't work - all the lights, timer, on/off switch, etc., seem to be working, but the water doesn't pour through the grounds to make the coffee
Does it make steam or can you hear the water boiling? Try and pour 4 cups of vinegar or lime away in it if it is clogged or plugged up from lme or mineral deposits, if it not getting hot( you can tell very easily by seeing if the plate the pot sits on is getting hot) then the thermocouple or heating element is shot.
Jan 26, 2009 | Krups 888 Centro
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups model 865 Coffe and Expresso maker manual
I NEED A MANUAL FOR A 865 KRUPS COFFEE AND EXPRESSO MACHINE, I DID NOT GET ONE
Jan 27, 2008 | Krups Coffee Makers & Espresso Machines
Krups Caffe Centro 888 Coffee Maker, Espresso Machine Logo
32 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
